System of differential equations
The discussion revolves around solving a system of differential equations related to planetary motion using MATLAB. Participants explore the formulation of the equations, implementation in MATLAB, and the use of numerical solvers like ode45 and ode113.
  • Homework-related
  • One participant presents a system of differential equations for planetary motion and attempts to implement it in MATLAB.
  • Another participant questions the implementation details, suggesting that the position should be updated using a delta value based on velocity.
  • A participant points out a misunderstanding regarding the state vector and emphasizes the need to update positions correctly.
  • Concerns are raised about the initial conditions being physically inconsistent, which may lead to numerical integration failures.
  • Suggestions are made to use ode113 instead of ode45 for better precision in orbital dynamics problems.
  • Links to external resources are shared to assist with MATLAB implementation and understanding of ODE solvers.
Participants express differing views on the correct implementation of the equations in MATLAB, particularly regarding how to update positions and the choice of numerical solver. The discussion remains unresolved with multiple competing approaches and suggestions.
Participants mention issues related to initial conditions and the mathematical formulation of the problem, indicating potential limitations in their current understanding or application of the numerical methods.
Individuals interested in numerical methods for solving differential equations, particularly in the context of physics simulations, may find this discussion relevant.
dRic2
Hi, I was trying to solve the simplest problem of planetary motion (for one planet).
The equations should be:
##F_x = m \frac {d^2x} {dt^2} = G \frac {Mmx} {r^3}##
##F_y = m \frac {d^2y} {dt^2} = G \frac {Mmy} {r^3}##
where ## r = \sqrt{x^2 + y^2}##
So I re-wrote the system like this:
##\frac {dx} {dt} = v_x##
##\frac {dy} {dt} = v_y##
##\frac {dv_x} {dt} = G \frac {Mmx} {r^3}##
##\frac {dv_y} {dt} = G \frac {Mmy} {r^3}##
I'm not sure how to implement this in matlab...
I tried this
Code:
function out = sis(t, s)
% s(1) is x
% s(2) is y
% s(3) is v_x
% s(4) is v_yglobal G Ms Mt
out = zeros(4,1);out(1) = s(3);
out(2) = s(4);r = sqrt(s(1)^2 + s(2)^2);out(3) = G * Ms * Mt * s(1) / (r^3);
out(4) = G * Ms * Mt * s(2) / (r^3);end
but It gives wrong results.
Thanks
Ric
Why do you set out(1) = s(3) and out(2) = s(4) shouldn't they be something like out(1) = s(1) + t*s(3) and out(2) = s(2) + t*s(4) ?
and is the v_z really v_y?
yes, my bad.
I want to use ode45 instead of manually implement the algorithm and I though that is the way to do it.
You misunderstood what I was asking. My understanding is that the s array is the state of the system and since s1 and s2 represent the position then you must update the position each time with a delta x and a delta y value.
The delta x is in fact ##vx * \Delta t## which in your case is t giving the ##out1=s1+vx*t## expression.
Do you see what I mean?
You'll have to elaborate.
Thanks @jedishrfu, very nice link!
First of all, I forgot the minus sign in front of $\frac GMmx/r^3$. And then, as concerned as I was with mathematics, I totally forgot about the physics of the problem! My initial conditions were wrong and physically inconsistent so the numerical integration kept failing.
Try ode113 instead of ode45, as it is a variable order solver that includes the results of several past time steps. It is better than ode45 for problems where high precision is required, such as orbital dynamics problems.
Example here:
https://www.mathworks.com/help/matlab/ref/ode113.html#bu6t62o-1_1
ode45 actually outputs more points than it computes - it uses interpolation to get a few extra points per time step, which results in nicer looking plots. That can be adjusted with the 'Refine' option.
Thanks @Krell. I was just experimenting with Matlab to get used to it, but it is very useful to know!
  • · Replies 19 ·
