Take non-required classes or spend more time on research?
4 replies · 2K views · last reply
Simfish
Okay, so there are some non-required classes that I'd like to take (that would probably help with my overall GPA). But in the end, is it better if I simply spend those hours in research, if those classes might interfere with my research output?
Here's a big thing though: my *total* overall output would be higher if I took a full classload and did research, simply because it would motivate me to work harder (and waste less time).
Also, is it uncommon for students to work on two projects at once? (especially if a professor is often absent?)
What is your degree? What are the classes? Are they helpful towards your research? How much time does your research demanding?
Astrophysics. Classes I'm considering: Senior-lvl statistics, Quantum II, a scientific computing course (in atmospheric sciences) where you use models. The stat and sci computing courses might help with research (the quantum II one probably won't). I'll self-study some Quantum II for the Physics GRE anyways.
My research isn't that demanding, but non-demanding research isn't going to give me stellar recs.
I would suggest the statistics and scientific computering if you think it's going to help that much. Otherwise, unless you feel the Quantum II will be helpful or you really want to do it. Keep the slot open for research or studying.
Stats would be very helpful if you are going to pursue astrophysics. When you are settling into a field in which observations are key (as in astronomy/astrophysics) you need to be able to sort through data and try to make sense of it, and justify your findings. Just my take. YMMV.
