How do dual vectors and tangent bases relate in coordinate functions?
  • Context: Graduate
  • Thread starter Thread starter nigelscott
    Bases Tangent
This discussion clarifies the relationship between dual vectors and tangent bases in coordinate functions, specifically addressing the equation dxμ∂ν = ∂xμ/∂xν = δμν. The gradient of coordinate functions (dxμ) represents the basis of cotangent space, while ∂ν denotes the basis of tangent space. The results hold universally, independent of whether the coordinate system is orthonormal, and are derived from the definitions of differentials and tangent vectors. The discussion emphasizes that the relationship between tangent and dual vectors is foundational and does not necessitate a metric for its validity.
  • Understanding of differential geometry concepts
  • Familiarity with tangent and cotangent spaces
  • Knowledge of differential forms and their properties
  • Basic grasp of coordinate transformations
  • Study the properties of differential forms in various coordinate systems
  • Explore the implications of the metric tensor in Riemannian geometry
  • Learn about the relationship between tangent and cotangent spaces in depth
  • Investigate the role of dual vectors in physics and engineering applications
Mathematicians, physicists, and students of differential geometry seeking to deepen their understanding of the interplay between dual vectors and tangent bases in coordinate systems.
nigelscott
I am trying to figure how one arrives at the following:
dxμν = ∂xμ/∂xν = δμν
Where,
dxμ is the gradient of the coordinate functions = basis of cotangent space
ν = basis of tangent space
I know that dual vectors 'eat' vectors to produce scalars. Is this demonstrated by absorbing d into ∂ so that dxμ ≡ ∂νxμ or is such an operation illegal?
I think those equations only hold if the coordinate system is orthonormal. The more general result would be that those expressions are equal to
$$\mathbf g(\partial_\mu,\partial_\nu)=g_{\mu\nu}$$
As regards proving the result, it depends on where one starts, in particular, how one defines ##\partial_\nu## and dxμ. Several different approaches are possible. The nature of the proof would depend on the nature of the definition. For some definitions, the result may even be part of the definition so that no proof is required.
By definition of the differential ##df##, it holds that
df(\dot\gamma) = \frac{df}{ds}
where ##\dot\gamma## is the tangent vector of a curve ##\gamma## parametrised by ##s##. In a coordinate system representation, this expression can be rewritten
df(\dot x^\mu \partial_\mu) = \dot x^\mu df(\partial_\mu) = \frac{df}{ds} = \frac{\partial f}{\partial x^\mu} \frac{dx^\mu}{ds}
using the linear property of a dual vector and the chain rule, respectively. This is satisfied for all tangent vectors if and only if
df(\partial_\mu) = \frac{\partial f}{\partial x^\mu}.
If you let ##f## be your coordinate function ##x^\nu##, you now obtain
dx^\nu(\partial_\nu) = \frac{\partial x^\nu}{\partial x^\mu} = \delta^\nu_\mu.
No, the result is completely general and an effect of how the differential is defined. I would not call ##g(\partial_\mu,\partial_\nu) = g_{\mu\nu}## a result as much as the definition of the components ##g_{\mu\nu}##. In contrast, the result above is general and does not even require a metric to be well defined (the natural product is between tangent vector and dual vectors, the metric is necessary only to define a product between vectors of the same type).
I find that it sometimes helps to go back to the Euclidean case. In the Euclidean case you can define two bases ##\vec E^\mu = \partial \vec x/\partial x^\mu## and ##\vec E_\mu = \nabla x^\mu##, respectively. These are the equivalents of ##\partial_\mu## and ##dx^\mu##, respectively (heuristically, essentially just remove the position vector). Each of these sets of vectors will generally not be orthonormal among themselves (in curvilinear coordinates), however it will still hold that
\vec E^\nu\cdot \vec E_\mu = \frac{\partial x^\nu}{\partial y^i} \vec e_i \cdot \vec e_j \frac{\partial y^j}{\partial x^\mu} = \frac{\partial x^\nu}{\partial y^i} \frac{\partial y^i}{\partial x^\mu} = \frac{\partial x^\nu}{\partial x^\mu} = \delta^\nu_\mu,
where ##\vec E^\nu## and ##\vec E_\mu## have been written down in component form in a Cartesian coordinate system ##y^i##.
Thank you. Now I understand.
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 35 ·
