Taylor remainder error bound for e^x approximation
2 replies · 3K views · last reply
viciousp
The approximation [tex]e^{x}=1+x+(x^{2}/2)[/tex] is used when [tex]X[/tex] is small estimate the error when [tex]\left|x \right|<0.1[/tex]
[tex]\left|R_{n} \right|<\frac{M(x-a)^{n+1}}{(n+1)!}[/tex]
Since the Taylor expansion goes to the second power I used the third derivative of [tex]e^{x}[/tex] which is just itself and found the maximum value that it can be between the domain [0,0.1] which is at [tex]e^{0.1}[/tex] then continuing the formula [tex](0.1-0)^{3}[/tex] then i divided it by 3! which gave me an answer of [tex]1.84*10^{-4}[/tex].
My book on the other hand used [tex]3^{0.1}[/tex] instead of [tex]e^{0.1}[/tex] and as a result the answer in the book was larger than my answer. So which answer is the right answer?
Depends upon what you mean by "estimate". Remember that neither of those answers will be the error- you can't determine the exact error this way. What you are saying is that the error is less than 1.98x10-4 while the textbook is saying it is less than a larger value (because e< 3) so both are correct. I don't know if your book has some reason for using "3" rather than "e". e gives a slightly more accurate estimate but they are both estimates.
The only reason I can imagine is that [tex]3^{0.1}[/tex] is easier to calculate because it's the solution of [tex]x^{10} = 3[/tex] and a Newton's method iteration would provide an accurate estimation quickly. The assumption, I suppose, is that if you are approximating [tex]e^x[/tex], you don't have the luxury of calculating it explicitly.
