Technical term for energy loss in indirect heating
popularscience
Suppose I heat a room directly by lighting a fire in the room, let's say it is a butane gas fire and it takes n BTU to raise the temperature by 10°C.
Now, suppose I don't like the smell of burning gas fumes and decide instead to move the same gas fire outside and boil water to generate steam to run a generator to produce electricity to power an electric heater in the same room and it takes 3n BTU to raise the temperature by 10°C.
Is there a technical term to descibe the 3 x BTU difference between direct heat and indirect heat in the above?
:welcome:
The word in your title; efficiency. I'm not sure what other word you are searching for.
I think it would be best to call it something like the "relative efficiency" because the original butane fire isn't going to be 100% efficient.
I don't see a problem with using "efficiency" as long as you describe clearly what you are talking about. As said, it isn't necessarily straightforward. For this situation, there is a potential difference between total and sensible energy output (lower vs higher heating value), that may still make the efficiency of the fire in the room less than 100%. And if the system is properly vented so as not to violate code/kill anyone, the ventilation should be factored into the efficiency as well.
