Tension in the cable of the lift
The discussion revolves around the tension in the cable of a lift moving in different directions and the relationship between tension, mass, and acceleration. Participants explore the application of Newton's second law in this context, focusing on the implications of upward and downward motion of the lift.
  • Homework-related
  • One participant states that the tension in the cable when the lift moves upward is twice that when it moves downward and seeks to determine the lift's acceleration.
  • Another participant suggests applying Newton's second law to establish the relationship between gravitational acceleration (g) and tension (T) for both upward and downward motion.
  • A participant proposes a method to express tension and acceleration, but later receives feedback indicating a misunderstanding of how to apply forces and accelerations in the equations.
  • There is a correction regarding the representation of forces and accelerations, emphasizing that only one acceleration should be used in the equation F = ma.
  • One participant arrives at an acceleration of A = g/3 but expresses uncertainty about its correctness and requests verification.
  • Another participant questions the direction of tension relative to weight in their equations, indicating confusion about the physical setup.
The discussion contains multiple competing views and unresolved questions regarding the application of Newton's laws and the correct interpretation of forces and accelerations in the context of the lift's motion.
Participants express uncertainty about their calculations and the application of concepts after a significant time away from physics, indicating potential gaps in understanding that may affect their reasoning.
jatin1990
The tension in the cable supporting a lift moving upward is twice the tension when the lift moves downward. What is the acceleration of the lift?
i think its only conceptual but still please show me the way how to think about it.
Thank you.
welcome to pf!
hi jatin19901! welcome to pf! :wink:
apply good ol' Newton's second law to find the relationship between a g and T for the two cases …
what do you get? :smile:
i am doing it like this , when lift is moving downward then , Tension(T) = Mass(m) * Net Acceleration ( Acc. due to gravity(g)+ Lift acceleration(a))
And when lift is moving upward then : 2T = M * (g-a) , and finding out the relation between a and g , i am getting , a=-g/3 , i have a option of g/3 , and i am getting -g/3 .
please correct me where i am wrong.
no no no no noooo :redface:
never do that, there is only one acceleration for one body
in other words: you can put as many forces as you like on the LHS of F = ma, but you can only put one acceleration on the RHS​
(of course, you can subtract accelerations of different bodies, to get the relative acceleration of the two bodies, but that's not this case)
g is not an acceleration (on the RHS), mg is a force (on the LHS)
try again! :smile:
try again! :smile:
I do not got your last line.
you mean? …
in F = ma, the only a on the RHS is the actual acceleration (what you, for some reason, are calling the "net acceleration" :frown:)
on the LHS, you put all the forces, and that includes the weight, mg :smile:
tiny-tim said:
you mean? …
oh ok , yes got the answer as A = g/3 , but i don't know whether it is correct or not , can u please check it. One more thing i have some questions to ask , can you please answer them here or do i need to start a another thread?
Thank you.
if you want us to check your calculations, you need to show them :wink:
always start another thread :smile:
when lift is moving upward i got , 2T+mg=-ma and when lift is moving downward , T+mg=ma , and then equate the T from both equations , is it right?
uhhh? :confused:
how can the tension be in the same direction as the weight??​
tiny-tim said:
uhhh? :confused:
Sorry for my stupidity , now i got it. As i am touching physics after two years , so this is the result. I hope i will get my command back upon physics with the help of this forum.
Thank you Tiny Tim for answering my questions very quickly every time.
