What is the tension on the elevator cable?
The discussion focuses on calculating the tension in an elevator cable under various conditions: accelerating upwards at 1.2 m/s², accelerating downwards at 1.2 m/s², and moving at a constant velocity of 0.50 m/s. The correct formula for tension when accelerating upwards is T = m(g + a), where m is the mass of the elevator (2.7 x 10³ kg) and g is the acceleration due to gravity (9.8 m/s²). For downward acceleration, the formula adjusts to T = m(g - a). The participants clarify that when the elevator is stationary or moving at constant velocity, the tension equals the gravitational force.
  • Understanding of Newton's Second Law (F = ma)
  • Basic knowledge of gravitational force (g = 9.8 m/s²)
  • Familiarity with free-body diagrams
  • Ability to manipulate algebraic equations
  • Learn how to derive tension equations for different acceleration scenarios in physics.
  • Study free-body diagram techniques for analyzing forces in various contexts.
  • Explore the implications of constant velocity on net force and tension in mechanical systems.
  • Investigate real-world applications of tension calculations in elevators and other lifting systems.
Students studying physics, particularly those focusing on mechanics and forces, as well as educators looking for examples of tension calculations in real-world scenarios.
kyletheskater
An empty elevator of mass 2.7x10 (3) kg is pulled upward by a cable at an acceleration of 1.2 m/s (2)
a) What is the tension in the cable?
b) What would be the tension in the cable if it was accelerating downward at 1.2 m/s (2)?
c) What would be the tension in the cable if it was moving with a constant velocity of 0.50m/s?
So far as I know,
F=m x a
I am pretty new to physics and I've been doing alright so far but these elevator tension questions are killing me. I actually have no idea where to go. When I worked it out (probably not right) I found the cable to have more tension in the downwards acceleration rather than upwards. I'm pretty sure I'm wrong I just need someone more experienced to tell me so. I would be really greatful for any help! Thanks!
Here are a couple hints (I hope they help):
- If the elevator was in free fall (accelerating downwards only due to gravity), the cable would not be exerting any force on the elevator.
- Also, if the elevator was just hanging there (not going up or down), the cable would have to exert how much force?
- If the first two hints helped, think about how much MORE or LESS force is required to get the elevator to accelerate up or down at the rates given
So when the elevator is stationary the forces would be equal since it is not accelerating. When it's accelerating upwards the cable should have more tension right?
The way I'm trying to solve it I found the upwards force and the downwards force in a free-body diagram and then adding them. Am I on the right track or am I missing something? I found another equation T=m(g+a) do I need to add both accelerations before calculating the force in a direction to which more than one acceleration is affecting it?
Correct. In fact, whenever the elevator is not accelerating (whether it's stationary or not), the forces are equal because anet = 0 (HINT for #3).
Correct again! Now, the key is how much MORE tension? Again, remember Fnet = manet. Since you're now getting the elevator to accelrate upwards with 1.2 m/s2 "more" acceleration, then how much MORE force does it take...
EDIT:
Yeah, that's what I was trying to hint at. I didn't see you already posted this. Whoops!
Ok I'm starting to get this a little better now but there is one thing that still puzzles me. You said how much "more" acceleration, but the upwards acceleration is going up and gravity goes down so wouldn't the acceleration be (9.8 m/s2 - 1.2 m/s2)? When I do this I get a higher force when the elevator is accelerating DOWNWARDS which just doesn't make sense!
Sorry for the confusion. To keep the elevator from accelerating upward or downward (basically to keep it at a constant velocity), the tension force MUST be equal to the force of gravity of the elevator. In essence, the cable is providing an upward acceleration of 9.8 m/s2 to balance out the downward acceleration of gravity. So, when the elevator has a net acceleration of 1.2 m/s2 upward, that means it has to supply that much MORE force.
So, the anet = acable - g.
Going down, the cable only requires enough force to keep the elevator going at whatever acceleration is needed. For example, if the elevator is to be in free fall (9.8 m/s2), the cable would provide NO force. If the cable were to accelerate downward at 9.7 m/s2, the cable only needs to provide a 0.1 m/s2 upward acceleration (and the force associated with it).
So, in this sense, anet = g - acable.
Does that make sense? Sometimes I find it easier to explain this on a board or in person instead of over the internet! Sorry!
OOOH ok I got it now thanks sooo much! You actually justed saved me :)
You're welcome. I'm glad I helped!
a) For when the elevator is accelerating upwards at 1.2m/s^2:
Tension = m(g+a)
= 2.7x10^3kg (9.8m/s^2 [upwards] + 1.2m/s^2 [upwards])
Is this correct? I'm trying to interpret this; g = 9.8m/s^2 [UP] because the Tension is acting opposite to gravities force on the elevator?
This would make sense because it would give me a greater tension when the elevator is accelerating upwards rather than downwards.
Another way that i did it prior to finding the tension equation was:
Fnet = Fgravity + Ftension rearranges to;
Ftension = Fnet - Fgravity
Would this equation work as well?
  • · Replies 19 ·
  • · Replies 19 ·
