Analyzing the Tether Ball Problem: Forces and Motion
  • Thread starter Thread starter Charanjit
    Ball Forces
The problem involves analyzing the forces acting on a tether ball that leans against a post. The setup includes specific measurements for the string length, ball radius, and mass, while neglecting friction between the ball and the pole.
  • Exploratory, Assumption checking
  • Participants discuss the forces involved, with initial attempts to identify the tension in the rope and the force exerted by the pole on the ball. There is mention of using a free body diagram to label forces.
Some participants have made progress on the first question regarding tension, while others are seeking confirmation on the calculated force exerted by the pole. There is an indication of collaborative effort, with some participants having received help from others or their instructor.
Participants express uncertainty about the correctness of their calculations, particularly regarding the force value not being accepted by an online system. The discussion reflects a mix of understanding and confusion about the problem setup and calculations.
Charanjit
1. Homework Statement
A tether ball leans against the post to which it is attached. The string is attached to the ball such that a line along the string passes through the center of the ball. The string to which the ball is attached has length 1.50 m and the ball's radius is 0.108 m and has a mass of 0.275 kg . Neglect any friction between the ball and the pole.
2. Homework Equations
F=ma
A=v^2/r
F=mv^2/r
3. The Attempt at a Solution
Have a free body diagram, but have no clue where to start.
What is the question?
Woops, sorry.
First question: What is the tension in the rope?
Second: What is the force the pole exerts on the ball?
Start by labeling the forces on the free body diagram.
Ok I got the first question figured out, need help with the second one.
I had help and worked out the second part which asks what is the force that the pole exterts on the ball, and I got 0.194. But my online system doesn't accept, maybe its wrong. Can someone confirm?
Work it out here.
Nevermind, had my instructor explain it.
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 28 ·
