How Can You Adjust Text Size When It's Not Visible in Composition Tools?
  • Thread starter Thread starter symbolipoint
Text size in composition tools can be adjusted using SIZE tags, although these controls are not visibly available in the toolbar. Users can toggle between WYSIWYG and markup modes by clicking the gearwheel icon, which reveals the underlying code. The correct syntax for BBCODE requires an equals sign before arguments, such as [size=2] for size 2 text. Many users may not be familiar with this coding, but quoting others' posts can provide insight into the correct usage. Overall, understanding and utilizing SIZE tags can enhance text appearance in posts.
symbolipoint
Education Advisor
How can text size be controlled during composing of a post? Not found in any tools above the composition field.
You can use SIZE tags like this.
Edit: Click the gearwheel icon to toggle between WYSIWYG and visible markup mode.
I see no tool for it above the composition field but since you mentions size tags, I should be able to apply such tags and test the appearance.
The gear icon only turns on or turns off the tools in the toolbar menu. The only text appearance controls I see are BOLD, Italicize, and Underline, and Strike-through.
A tagging test:
[size 2]size 2[/size]
[size 4]size 4[/size]
[size 8]size 8[/size]
That would work, if I know the correct syntax for these tags.
Apparantly I do not know the needed syntax.
Trying again after some guidance from Ibex:
size 2[/size]
size 4[/size]
size 8[/size]
As with any coding, the easiest thing to do is plagiarise. What I meant you to do (although I did not say - apologies) was quote my post and click the gear icon to drop out of WYSIWYG and see the tags I used.
Generally, BBCODE seems to require an equals before arguments - so it's to get size 2 text
Likes symbolipoint
Yes, I just did that a few seconds ago upon seeing your last message. I did not know I would see that code. This is new to me even if not new to many other members. (I should make more use of it to see how some things are produced, when they look interesting.)
I added the text size to the editor
Likes Tom.G, Wrichik Basu and symbolipoint
Hello everyone, I recently revisited Physics Forums after a long hiatus (about 4-5 years) and started catching up on the recent discussions. What immediately struck me—and what inspired this thread—is seeing so many of the exact same user names in the "Latest Posts" section who were just as active when I was last here! To the dedicated, long-term, and continuously active members of this community: What keeps you coming back and contributing regularly after all this time? Is it the joy...
  • · Replies 21 ·
