The best way to solve x³ + bx = c
  • Context: Graduate
  • Thread starter Thread starter logics
The discussion revolves around solving Khayyàm equations of the form x³ + bx = c, particularly when b is not a square number. Participants explore various methods, algorithms, and the number of operations required to find solutions, while also considering the implications of these methods on the nature of the equations.
  • Some participants inquire about the quickest way to solve the equation x³ + bx = c when b is not a square number, providing specific examples.
  • There is a discussion about the number of operations required to find solutions, with one participant suggesting that 11 operations are needed to compute the solution.
  • One participant presents a method involving logarithms and complex numbers, but others challenge the validity of this approach, indicating it may not be correct.
  • Another participant proposes a quadratic approach to find a³ based on the original equation, suggesting a method that involves several operations to derive a solution.
  • Concerns are raised about the implications of negative values for b and how they affect the number of solutions to the equation.
  • Participants discuss the historical context of cubic equations and the existence of imaginary solutions, questioning how these relate to the nature of the solutions for the given equations.
  • There is a mention of Cardano's cubic formula and its relevance to the discussion, with participants seeking to clarify the method's name and its applicability to various forms of cubic equations.
  • Some participants express uncertainty about the existence of a single solution for cubic equations and how to identify such cases.
  • Questions arise about the possibility of extending similar methods to quintic equations and whether there are established algorithms for such cases.
Participants exhibit a mix of agreement and disagreement regarding the validity of proposed methods and the implications of certain mathematical approaches. There is no consensus on the best method to solve the equations or the nature of the solutions.
Limitations include unresolved mathematical steps in the proposed methods, dependence on definitions of terms like "solution," and the implications of negative values for b. The discussion also reflects varying interpretations of historical mathematical concepts.
logics
What is the quickest way to solve a Khayyàm equation when b is not a square number?
Consider: x³ + 7x = 606,087.936,
( x³ + 5x = 132906...)
using the best algorithm, how many operations are required to find the solution ( x = 84.6, 51... ) ?
If we regard it as a reduced/depressed form, is it possible to find the original equation (or are there more than one) having the same solution?
Mathematics news on Phys.org
u mean 606087.936...? or 606087936
Thanks, Victor, I corrected the typo, but, 846 or 84.6, I suppose the operations do not change.
x^3+bx=c
x(x^2+b)=c
x(x+ib)(x-ib)=c
ln (x(x+ib)(x-ib))=ln c
ln x + ln (x+ib) + ln (x-ib)=ln c
ln x + ln |x| + iarg(z) + ln |x| - iarg(z)=ln c
ln x + ln x + ln x = ln c
3ln x = ln c
ln x = (ln c)/3
x=e^(ln c)/3
now I look at my answer I got confused... cause the formula does not contain b so it is wrong?
Your result, x=\exp((\log c)/3) is a convoluted way of writing x=\sqrt[3]c.
What you did with logarithms is wrong.
\ln(x+ib) should be \ln\sqrt{x^2+b^2}+i\cdot \arg(z)
Because for a complex number x+iy, we can convert it into the mod-arg form r e^{i\theta} and then \ln\left(r\cdot e^{i\theta}\right)=\ln(r)+i\theta where r=\sqrt{x^2+y^2}, \theta=\tan^{-1}\left(\frac{y}{x}\right)
For any numbers, a and b, (a- b)^3= a^3- 3a^2b+ 3ab^2- b^3 and 3ab(a- b)= 3a^2b- 3ab^2 so that (a- b)^3+ 3ab(a- b)= a^3- b^3. That is, if x=a- b, m= 3ab, n= a^3- b^3, x^3+ mx=n.
Now that will fit x^3+ 7x= 606,087.936 with 3ab= 7, a^3- b^3= 606087.936.<br /> <br /> Of course, that means b=7/a so a^3- 7^3/a^3= 606087.936. Multiplying through by a^3, gives (a^3)^2- 606087.936a^3- 7^3= 0, a quadratic function for a^3. We can solve for a^3 using the quadratic formula: <br /> a^3= \frac{606087.936\pm\sqrt{(606087.936)^2+ 4(7^3)}}{2}<br /> <br /> So computing a^3 involves: <br /> 1) Find (606087.936)^2- one operation<br /> 2) Find 4(7^3)- three operations<br /> 3) Add them- one operation<br /> 4) Take the square root- one operation<br /> 5) Add to or subtract from 606087.936- one operation<br /> 6) Divide by 2- one operation<br /> 7) Take the cube root<br /> <br /> That is, 8 operations are required to find just a. We don&#039;t have to repeat all that to find b^3, we have a^3- b^3= 606087.936 so b^3= a^3- 606087.936, a ninth operation, and then we must take the cube root, a tenth operation, to find b itself. Finally, x=a- b after a total of eleven operations.
HallsofIvy said:
That is, 8 operations are required . Finally, x=a- b after a total of eleven operations.
Thanks a lot, Sir.
What is the name of this method?, only 11, actually 9 [if we consider 7³ just one] operations is definitely an eccellent achievement, it should apply also to equations where b is negative, in the region where there is only one solution i.e.:
x³ -9x = 148400 (x = 53, c> 10,3...) or maybe even when x > 3.
Can we say this algorithm gives always the or one of the solutions of a depressed cubic?
Is that method valid, Mentallic, anyway?, could you, please, write the right procedure applying it to x³+9x=149354
No, it doesn't get us any closer to solving the problem at hand. I was just showing n_kelthuzad why his solution was invalid.
HallsofIvy said:
...We can solve for a^3 using the quadratic formula:
a^3 = \frac{606087.936\pm\sqrt{(606087.936)^2+ 4(7^3 ?)}}{2}
a) Probably that is a typo, shouldn't it be 7³/ 27 ?
a^3 = \left(\frac{x + \sqrt{x^2 + 4*b}}{2}\right)^3 = \frac{c+\sqrt{c^2 + 4 * b^3/3^3}}{2}
b) What happens if b is negative: x³ - bx = c, how do we find the other two solutions?
c) * Is there a similar brilliant solution for quintic equations with only one solution? :
\ x^5 + bx^3 = c ,... x^5 + bx = c,... x^5 + bx^3 + cx =d, ...
*should I make a new thread for this question?
Can we find an equivalent original equation x³ + bx² +cx... having only one solution : 84.6?, does it depend on the relation between b and c?.
logics said:
Thanks a lot, Sir.
That is "Cardano's cubic formula"
http://en.wikipedia.org/wiki/Cubic_function
I don't know what you could mean by "the" solution of a cubic.
I consider the question from the point of view of logics:
If, [on a "function explorer"], you look at the curve x³+ bx = c you see a curve similar, almost identical, to x³= c.. Could one ever say that x³ = c has one real and two imaginary solutions? Am I missing something?
I suppose that if, historically, "casus irriducibilis" had not occurred, we would not be here to talk about imaginary solutions (or numbers).
I know the fundamental theorem says "nth power-n zeroes", but I suppose it is a general frame and it is understood "at most" with b> 0, and only odd powers : x³+x;.. x^5 + x³+ x, etc..., there is only one solution, am I wrong?.
That is why I ventured to say that x³ + bx= 0 is a cubic equation with only one solution. How should one identify these equations?
On the other hand, also a cubic with b<0 or with even power has 2/more roots in an infinitesimal region of the y-axis, elsewhere we find the solution.
I hope I made myself clear.
Is there an algorithm to solve a depressed quintic x^5+... when there is only one solution?
P.S: at wolfram, sometimes they show the algorithm, a formula starting with
\frac{\sqrt[3]{2b/3}}{\sqrt[3]{\sqrt{3}\sqrt{4b^3+27c^2-9c}}} ...
is that any better?
