The commutator of position and momentum - interpretation?
The discussion focuses on the geometric interpretation of the commutation relation between position and momentum operators in Quantum Mechanics (QM). It establishes that the non-commutativity of these operators prevents simultaneous diagonalization, leading to the conclusion that momentum acts as the generator of translations in position space. The mathematical formulation presented includes the semi-classical wave function and the infinitesimal translation operator, demonstrating the relationship between the momentum operator and the gradient of the action in classical mechanics.
  • Understanding of Quantum Mechanics principles, specifically operator theory.
  • Familiarity with the commutation relations in quantum physics.
  • Knowledge of the semi-classical wave function and its implications.
  • Basic grasp of classical mechanics and the concept of action.
  • Explore the mathematical derivation of the WKB approximation in Quantum Mechanics.
  • Study the implications of the Heisenberg uncertainty principle on position and momentum operators.
  • Investigate the role of unitary operators in quantum state transformations.
  • Learn about the relationship between classical mechanics and quantum mechanics through the Correspondence Principle.
Quantum physicists, students of Quantum Mechanics, and anyone interested in the mathematical foundations of operator theory and the interpretation of commutation relations.
Kontilera
Hello friends!
Im trying to get an geometric interpretation of QM and am now confused about the commutation relation between operators.
Lets take momentum and position... sure, the fact that they don't commute show that we can not diagonalize them simultanesly.
But what is the interpretation of the matrix that we get we we take the commutator? (i hbar I.)
Is it the difference we get when we change the order of a translation in position space and a translation i momentumspace?
(I cannot help to try to relate this commutator relation to the fact that P is used when defining the unitary operator for position translation etc.)
All the best!
/ Kontilera
Sakurai refers to classical mechanics to explain why we should expect momentum to be the generator of translation in position space, is there any nice mathematical way to see this? Or is it a physical postulate that I should accept to work?
The semi-classical form of the wave function of a particle is:
<br /> \Psi(\mathbf{x}, t) \equiv \langle \mathbf{x} \vert \Psi, t \rangle \sim \exp \left( \frac{i}{\hbar} S(\mathbf{x}, t) \right)<br />
This should be accepted as a kind of a postulate of Quantum Mechanics, which is the mathematical formulation of Bohr's Correspondence Principle, and a starting point in deriving the WKB approximation to the Schroedinger equation.
Now, as you said, the action of an infinitesimal translation operator is:
<br /> \hat{T}(\delta \mathbf{a}) \, \left\vert \mathbf{x} \right\rangle \equiv \left\vert \mathbf{x} + \delta\mathbf{a} \right\rangle \approx \left[ \hat{1} - \frac{i}{\hbar} \, \delta \mathbf{a} \cdot \hat{\mathbf{P}} \right] \, \left\vert \mathbf{x} \right\rangle<br />
Multiplying from the left by a state bra \langle \psi \vert, we get:
<br /> \langle \psi \vert \mathbf{x} + \delta\mathbf{a} \rangle \approx \langle \psi \vert \mathbf{x} \rangle - \frac{i}{\hbar} \delta\mathbf{a} \cdot \langle \psi \vert \hat{\mathbf{P}} \vert \mathbf{x} \rangle<br />
Taking the hermitian adjoint of the above equality and using Taylor's formula:
<br /> \langle \mathbf{x} + \delta\mathbf{a} \vert \psi \rangle \approx \langle \mathbf{x} \vert \psi \rangle + \delta\mathbf{a} \cdot \nabla \langle \mathbf{x} \vert \psi \rangle<br />
we get the following expression for the action of the generator of translations in x-representation:
<br /> \left\langle \mathbf{x} \right\vert \hat{\mathbf{P}} \left\vert \psi \right\rangle = \frac{\hbar}{i} \, \nabla \, \left\langle \mathbf{x} \right\vert \psi \left. \right\rangle<br />
On the other hand, the gradient of the semiclassical wave function is:
<br /> \nabla \Psi(\mathbf{x}, t) \sim \frac{i}{\hbar} \nabla S(\mathbf{x}, t) \, \Psi(\mathbf{x}, t)<br />
Thus, we have:
<br /> \left\langle \mathbf{x} \right\vert \hat{\mathbf{P}} \left\vert \Psi, t\right\rangle \sim \nabla S(\mathbf{x}, t) \, \left\langle \mathbf{x} \right\vert \Psi, t \left. \right\rangle<br />
But, in classical mechanics, we know that the gradient of the action w.r.t. to the endpoint of the trajectory \nabla S(\mathbf{x}, t) is the momentum \mathbf{p} of the particle. Therefore \hat{\mathbf{P}} is indeed the linear momentum operator in Quantum Mechanics.
  • · Replies 32 ·
  • · Replies 17 ·
