The concept of 'unknowns' in equations
  • Context: Undergrad
  • Thread starter Thread starter Jehannum
    Concept Unknowns
The discussion centers on the concept of 'unknowns' in mathematical equations, emphasizing the necessity of multiple equations for multiple unknowns. It explores the nuances of what constitutes an 'unknown', suggesting that knowing certain properties, such as the sign of a variable, can aid in solving equations. The conversation highlights the informal use of the term 'unknown' and its relationship to variables, proposing that a precise mathematical definition is complex. The participants agree that understanding the degrees of unknownness can influence the approach to solving equations.
  • Understanding of basic algebraic equations
  • Familiarity with mathematical terminology such as 'variables' and 'unknowns'
  • Knowledge of logical statements and quantifiers in mathematics
  • Experience with solving simultaneous equations
  • Research the concept of 'variables' in mathematical logic
  • Explore the implications of known properties on solving equations
  • Study the formal definitions of quantifiers in mathematics
  • Learn about the methods for solving simultaneous equations
Mathematicians, educators, and students interested in deepening their understanding of algebraic concepts, particularly those exploring the nature of unknowns and variables in equations.
Jehannum
You can solve an equation with one unknown. You need two different equations for two unknowns, and so on.
This implies a binary distinction between 'known' and 'unknown'. But are there grades or shades of unknown? For instance, if you know that a variable is negative but not its magnitude, can that help solve an equation? If so, is there any field of study on what the different degrees of unknownness are?
Mathematics news on Phys.org
Sometimes, e. g. you can find a unique solution for ##x^2 = 4## if you know x is negative.
You can express this as an inequality, x<0, or directly specify the domain: ##x \in (-\infty,0) \subset \mathbb{R}##.
As long as you don't go to probabilistic analyses, all that knowledge can be expressed in one of the ways described above.
Talking in the context of a specific problem in basic math, an entity or quantity is either known or unknown. In order to be labeled as known, it must fulfill some criteria or in other words, some properties of it must be precisely known, one of which is its value. If on the other hand there is even one such property that is not known, then the quantity is unknown.
This is very abstract because it depends on what kind of "help" you mean here. It can help in a qualitative manner in general, but you still have to find its value, unless you're given more data about the variable. It may also be the case as mfb points out, that knowing about its sign, will help to choose among different solutions.
That depends on what you mean by "solve". One can "solve" the equation x + 3 = x and obtain the result that there are no solutions.
In speaking of equations, I see no distinction between the term "unknown" and the term "variable". It is actually very difficult to give a precise mathematical definition of a "variable". It would require defining the concept of quantifiers and the concept of the scope of a variable.
What implies a binary distinction between "known" and "unknown" ?
Are you looking for terminology that's based on the solution(s) of simultaneous equations ?
The concept of an "unknown", or a variable with "unknown value" is an informal way of speaking. Mathematically, solving an equation, say, ##x^2+x-2 = 0##, is simply deducing a statement such as this: "##(\forall x)(x^2 +x - 2 = 0 \Rightarrow (x = 1 \text{ or } x = -2))##". Generally, if ##P(x)## denotes an equation in ##x##, then we want to derive a statement on the form ##(\forall x)(P(x) \Rightarrow Q(x))##, where ##Q(x)## is some satisfactory formula describing ##x##, which we call the solution to ##P(x)##. Usually ##Q(x)## is a formula on the form ##x = a##, but can also be things like ##1 = 0## which is a false statement in itself. In the latter case we say that ##P(x)## has no solutions. In the former case, we can replace an equation ##P(x)## with a suitable solution formula ##Q(x)##.
There is not really a mathematical thing called an "unknown". Formally, it's the usual business with variables, formulas and sentences. We speak of an unknown out of economical reasons, and the fact that writing things out with logical formality is more trouble than it's worth.
And what about ##P(x)## given as ##\sqrt{x^2+x+3} = x##? When you "solve" it you get ##Q(x)## as ##x=-3## which is clearly not the solution.
Good observation. Of course, what we do is derive a statement such as ##(\forall x)(P(x) \Leftrightarrow Q(x))## instead. It is usually easy to modify a potential solution ##Q(x)## (for which ##P(x) \Rightarrow Q(x)##) in order to get a proper solution ##Q(x)## (for which ##P(x) \Leftrightarrow Q(x)##) by testing each potential value of ##x##.
