The definition of multiplication
The discussion centers on the definition of multiplication, highlighting its limitations when applied to non-integer numbers such as e and pi. Participants assert that multiplication extends from integers to rational and real numbers through established mathematical constructs, including the field of fractions and Cauchy sequences. The conversation also critiques the notion that multiplication can solely be defined as area, emphasizing that multiplication is fundamentally a binary operation that can be interpreted in various contexts, including complex numbers and matrices.
  • Understanding of Peano axioms and their role in defining natural numbers
  • Familiarity with the construction of rational numbers from integers
  • Knowledge of Cauchy sequences and Dedekind cuts in real number construction
  • Basic concepts of complex numbers and their operations
  • Research the construction of real numbers using Cauchy sequences
  • Study the implications of the Peano axioms on number theory
  • Explore the properties of complex numbers and their geometric interpretations
  • Investigate the various definitions and interpretations of multiplication in different mathematical contexts
Mathematicians, educators, and students interested in advanced mathematical concepts, particularly those exploring the foundations of multiplication and its applications across different number systems.
GarageDweller
Warning: Semantics battle may ensue, tread lightly
So I was wondering the other day, the repeated-addition definition of multiplication only works for integers, for example you cannot use this to calculate the square of e or pi.
So is there a rigorous definition for multiplication that is viable for all numbers?
Mathematics news on Phys.org
If you believe in multiplication of integers, it extends to the rationals and reals when you construct the rationals and reals out of integers.
The rationals are constructed as the field of quotients of the integers.
http://en.wikipedia.org/wiki/Field_of_fractions
(The article's a little general. In the Construction section, just think "integers" when they say "commutative pseudo-ring" and the construction's the same).
Then the reals are constructed as equivalence classes of Cauchy sequences of rationals, or alternately, Dedekind cuts of rationals.
http://en.wikipedia.org/wiki/Dedekind_cut
In each construction, from the integers to the rationals and from the rationals to the reals, addition and multiplication are defined based on what we already have. In other words multiplication of rationals is defined using multiplication of integers, and multiplication of reals is defined using multiplication of rationals.
I'm leaving out all the details, but this is the outline of the definition of multiplication of real numbers based on multiplication of integers.
We can go down the other way too. Where does multiplication of integers come from? It's ultimately defined in terms of the successor operation in the Peano axioms of the natural numbers.
http://en.wikipedia.org/wiki/Peano_axioms
The definition of multiplication is area. (my never ending mantra)
Your definition is not very useful (or correct). If my walking speed is 3.5 miles/hr and I walk for 2 hours, I go a distance of 7 miles. That in no way should be considered an "area."
In the land of units, my definition is correct. As soon as you apply measurement of specific units you have changed the system from mathematics to miles/hour. there are no fluid ounces in that system either.
Please explain i^2=-1 or (-1)^2=1 as area...
"In the land of units" - did you mean in problems where there are no units, such as mi/hr, fl. oz., etc.? Or did you mean dimensionless units?
Your mantra did not specify that you were talking only about the product of two numbers. Certainly, any product of two real numbers could be interpreted as an area, but that's not the only interpretation.
Of course it is not the only definition, however, as a fundamental definition, it is the one that is the most intuitive. as for i, you may spend the next few centuries explaining where that fits on the number line. I use are to explain multiplication when defining multiplication as "repetitive addition" fails. It fails if both numbers are not integers.
That is an interpretation not a definition.
Or you could spend 5 minutes explaining the Argand plane.
And your explanation fails in other spaces.
OK, here's a definition, multiplication is an operation.
btw, operations on i are defined, we do not know how to multiply i*i, we define its result. As far as multiplication goes my definition comes from the historical need to define ownership of land.
Your first statement is not true- we define i first, then show that i*i= -1. And, as has been pointed out before, "multiplication is area" is not even a "definition".
Calculating areas is one of the applications of multiplication, similarly vector fields historically arose from the concept of fluid velocity fields, but the concept can be applied to electromagnetism
Why just numbers?
You talk of vectors in later posts. Do you wish to exclude vector multiplication?
coolul, if you are willing to learn you are not so far from the mark with this, although it needs tidying up with some conditions.
Multiplication is a binary operation on a set.
Depending upon circumstance we may wish to restrict the output of this operation to other members of the set or we may wish to allow it to map to another set.
We can add further useful restrictions again depending upon circumstance eg
the requirement that ab = ba (or not)
etc.
The reason defining i first does not solve the i*i result. Because if we take i = \sqrt{-1}. it fails for i*i because we get 2 results depending on order of operations. Because of rules of exponents, \sqrt{-1} * \sqrt{-1} can result in \sqrt{(-1)(-1)} or \sqrt{(-1)^2}, now if we square first the answer is +1, if we don't it's -1, that is why i*i must be defined, because complex operations must be restricted.
The rules of exponents do not hold for negative numbers.
You can define i as the complex number with r=1 and arg =Pi/2 .
Then, multiplication z1z2 is given by the product of the
moduli and the sum of the arg. Yes, in some cases you have to mod out the sum
of arguments by 2π , but that is not a problem here. I don't see your point.
This is probably circular. The theorems showing that you can represent complex numbers this way usually involve i already. Even if you could eliminate this issue, you are going to be doing acrobatics to define the complex numbers and prove these theorems without mentioning i.
But we don't. The standard definition of the complex numbers is as pairs of real numbers, (x, y) with addition defined by (a, b)+ (c, d)= (a+ c, b+ d) and multiplication by (a, b)*(c, d)= (ac- bd, ad+ bc). We can map the real numbers to that by the identification of x with (x, 0). We define "i" to be (0, 1) and then show that i*i=(0, 1)*(0, 1)=(0*0- 1*1, 0*1+ 1*0)= (-1, 0), the complex number identified with the real number -1.
You said the magic word "define", that has been my assertion all along, calculations involving i require the result to be defined. We have rules that govern the results, but no operation takes place, like no operation takes place with 3x, until we know the value of x. 3x is defined as 3x. Last comment by me as all of you are much more knowledgeable about these matters. Do me one last favor, calculate the area of a triangle without multiplication.
What will that show?? If you want to say that multiplication is somehow useful in calculating areas, then you are right.
The thing is that you can't define multiplication as just "area". The problem is that you never really defined area. So the definition is quite shady.
We define the area of a rectangle to be it's base times height.
We do not define multiplication to be the area the rectangle with said base and height.
Do you understand the difference?
A simple definition of multiplication is 'do to the left-hand-side what the right-hand-side does to unity'.
On the reals unity is 1, so for 2 * 3, what the right-hand-side does to unity is to physically stretch three-fold.
On the complex numbers unity is 1+0i. so for z * (2+2i) the right hand side stretches unity by sqrt(8) and rotates it by 45 degrees.
On matrices 'unity' means the identity matrix, and the right-hand-side represents a scale, rotation, stretch, sheer upon identity.
That really only works if multiplication is already defined, since 3 only "stretches" unity by being multiplied with it.
scaling is only multiply on 1d numbers and could be defined as repeated addition.
But for complex, multiply is scale and rotation. For matrices it is scale, rotate, stretch, shear, and for other groups it can involve even more combinations of actions.
Where's the "shakes head" smiley when you need it?
TGLad, did you read the first post of this very thread? You can't define ∏2 as repeated addition.
Doesn't some of this only apply to square matrices?
I realize I need to extend my earlier definition slightly.
Muliplication is a binary operation on a set or two sets...
Since the operands may be drawn from different sets eg scalar multiplication of a vector.
This is always the way with maths we seek to extend include not deny and exclude - it is called generalisation.
  • · Replies 16 ·
  • · Replies 26 ·
  • · Replies 31 ·
  • · Replies 16 ·
