The final velocity = initial velocity + acceleration x time
17 replies · 2K views
jamiebean
attached below:
final velocity=initial velocity + acceleration x time
I first calculated initial velocity:
√7.09^2+1.07^2=7.17028
acceleration=√7.22^2+2.47^2= 7.63
then i substituted all values into this equation:
so, final velocity=82.0285
so the magnitude=
final velocity-initial velocity= 74.858271
is this correct?? thank you!
jamiebean said:
Homework Statement:: attached below:
Relevant Equations:: final velocity=initial velocity + acceleration x time
so the magnitude=
It's not correct. Velocity and acceleration are vectors.
Here you have calculated the initial speed.
then how can i calculate the initial velocity with the equation given? thank you!
You are given the initial velocity. In the link you included it says so explicity.
umm i don't understand.. instead of the form of velocity provided in the question, how can i change it into one value?
Velocity is a vector quantity. In general it has three components: in the x, y and z directions (or i, j, k if you prefer).
You'll need to learn to work with vectors. You can't reduce a vector to a single value.
then how should i calculate the magnitude of the velocity?
thank you!
thank you!
You want the magnitude of the final velocity. First, use the initial velocity vector and the acceleration vector to find the final velocity vector. Only then can you find the magnitude of that vector.
do i multiply the components of the initial velocity with acceleration, which i calculated as: -7.7254i,17,5123j
Eh? Multiply a velocity by an acceleration? Certainly not.
Think: if the velocity is in ms-1 and the acceleration is in ms-2 that would give you something with units m2s-3.
Besides, that is no way to multiply vectors. There are only two ways to multiply two vectors (at this level of maths): dot product and cross product. Cross product is only in 3D, so for 2D you only have the dot product. That multiplies two vectors to produce a scalar, not another vector: (a,b).(c,d)=a.c+b.d.
Use the relevant equation you quoted in post #1.
I don't know about the OP, but I find the notation confusing... could we not write something like:
An object has an initial velocity of ##(-1.07 , 7.09)ms^{-1}## and constantly accelerates at ##(7.22 , 2.47)ms^{-2}##. What is the magnitude of the velocity after 9.81s.
Or, is that something else. Apologies, for minor hijacking.
An object has an initial velocity of ##(-1.07 , 7.09)ms^{-1}## and constantly accelerates at ##(7.22 , 2.47)ms^{-2}##. What is the magnitude of the final velocity after 9.81s.
Yes, that's just another notation for the same thing. Whether it is confusing depends on what you are used to.
The ##\hat i, \hat j,\hat k## notation has benefits in writing out the expansion of a cross product.
Do the calculations for the ##i## and ##j## components separately, using the ##i## and ##j## components of initial velocity and acceleration. That will give you a final velocity with ##i## and ##j## components.
i used this equation:
then got the final velocity=69.7582i+31.3207j
so, the magnitude of velocity=
=76.84i+24.23j
Right, but you should not quote more sig figs than in the given data. You only have 3 for acceleration, so 69.8i+31.3j
jamiebean said:
magnitude of velocity=final velocity-initial velocity
No, that would be the change in velocity. You are asked for the magnitude of the final velocity.
For a vector ##\vec v=x\hat i+y\hat j## the magnitude is ##\sqrt{\vec v.\vec v}=\sqrt{(x\hat i+y\hat j).(x\hat i+y\hat j)}=\sqrt{x^2+y^2}##.
so, the answer should be 76.5?
thanks a lot!
