Raymond31415
- 16
Is there a limit to how long a transistor, like in a cpu, can be constantly on?
The discussion centers on the operational limits of transistors, particularly regarding how long they can remain continuously on without degradation. Key factors include the product of voltage drop and current, which determines the maximum power dissipation. Bipolar and FET transistors have defined safe operating areas (SOA) that must be adhered to, with specific attention to maximum rated voltage and current. If operated within these parameters, transistors can function for extended periods, potentially indefinitely, depending on the application and conditions.
PREREQUISITESElectronics engineers, circuit designers, and hobbyists interested in optimizing transistor performance and understanding operational limits in various applications.
Raymond31415 said:I see how that can be used to calculate a power unit but how would that translate into real time, eg: ms,s or minutes.
Raymond31415 said:I was planning on using a transistor on for periods of hours at a time, or a day at the most, operating at the lowest voltage and current possible, but I haven't been able to find anything on the internet about operating tolerances for npn and pnp transistors.
Skiddaw said:If this is a general question then I believe the general answer is "there is no limit to turn-on time" as long as the power/temperature parameters are kept within specification.
