The Power of Magnetic Motors: Research and Results
  • Thread starter Thread starter anu08
    Magnetic Motors
Research on pure magnetic motors focuses on reshaping magnetic fields to create unidirectional force on a rotor by shielding the magnets. The concept involves manipulating the vector forces as magnets approach and pass each other, potentially leading to increased force in one direction. While some users express optimism about the feasibility of these motors, there are concerns about the fundamental principles of energy conservation and the source of energy for such devices. The discussion highlights a desire for practical engineering insights rather than theoretical debates, emphasizing the challenge of visualizing and understanding the mechanics involved. Overall, the viability of magnetic motors remains uncertain, raising questions about their potential for real-world application.
anu08
I have been doing some research on pure magnetic motors. I have seen countless vidoes on youtube.. [ http://www.youtube.com/watch?v=ZI4NDrPQ2rA&feature=related ] for one. In these type of motors use the concept of "reshaping" the magnetic fields to allow unidirectional force on a rotor. they do this by Shielding the lead edge of the magnets (both rotor and stator) to change (reduced the force of )the vector that slows the rotor as the magents approach each other. Once the magnets are lined up.. the vector is pushing straight into the rotor, which causes no force in either direction, but once the magnets have passed the center alignment the vector force is now larger then the force required to bring the next magnet pass the center point...
I have made a few these shielded magnets.. and I have to say.. I'm a little... convinced that this just may work.. When I use just my hands and pass the two magnets past each other there is definely more force in one direction then there is the other.
Has anyone out there tried this? Seen this? or know how i can talk to the dude in the video?
---It's all about mind over matter, I no longer mind, Cause you no longer matter
Are you trying to make a free energy machine that uses magnets?
We all dream of something like that.. but no.. I just want to understand if it's possible..
Seems to me that once you say the phrase, "Free energy", your labeled a freak, conspiricy threorist or far far worse.. This is an engineering site.. I wanted real answers from real engineers. Therory's are great, until you try to put them into practice.
I just want to know.. is this possible? simple question. Not so simple answer.
The next question will be if it is possible. why NOT build one.?
Well, I'm having trouble visualizing what you're describing, but my guess is you're missing an important part of the force balance due to a lack of understanding of how magnetic shielding works.
The best question you can ask yourself about this idea is: since magnets are not an energy source, where is the "motor" supposed to get its energy?
EDIT- This topic has also been covered some time ago in the S&D forum: https://www.physicsforums.com/showthread.php?t=103813
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
