The problem of excitation of vibrations during collisions
The discussion focuses on solving a physics problem involving a collision between a ball and a system of two identical balls connected by a massless Hookean spring. The initial conditions include the mass of the balls, their initial velocities, and the spring's stiffness. Participants emphasize the importance of applying the laws of conservation of momentum and energy to determine the final velocities of the first ball and the center of mass of the second system. It is established that the collision can be treated as absolutely elastic, and the assumption that the collision occurs before significant spring compression is valid.
  • Understanding of conservation laws in physics, specifically momentum and energy conservation.
  • Familiarity with Hookean spring mechanics and its properties.
  • Knowledge of elastic collisions and their characteristics.
  • Ability to solve equations involving multiple variables and constraints.
  • Study the principles of elastic collisions in one-dimensional systems.
  • Learn how to apply conservation of momentum and energy in collision problems.
  • Explore the dynamics of systems involving springs and mass interactions.
  • Investigate the mathematical techniques for solving systems of equations with multiple unknowns.
Physics students, educators, and anyone interested in understanding collision dynamics and spring mechanics in elastic systems.
reterty
Dear colleagues, my problem is following:
The ball of mass
with the initial velocity
collides with a system of two identical balls of mass
each, connected by a massless hookean spring with stiffness
and length
It is necessary to find the final velocities of the first ball and the center of mass of the second system, considering the impact to be absolutely elastic and occurring along the line through the centers of the balls and the spring.
The law of the momentum conservation has form: :
. I can always write the law of the energy conservation but there is the energy of the elastic deformation and I don't know how to derive the expression for the final value of deformation. Moreover, event in that case we will have only two equation with three unknown variables
You get an additional equation using another conservation law that you did not mention.
(Edited to strike through irrelevant statement)
It is not clear what you mean by "final velocities". Is it perhaps "final" as in "immediately after the collision"?
Can you qualitatively describe the motion of the two-mass system after the collision?
Оk, I can solve this problem only in supposition
that immediately after the impact, two colliding balls get such momentums as if there is no spring at all.
Is it reasonable assumption?
It is reasonable to assume that the collision is over before the spring is appreciably compressed. You can use energy and momentum conservation to find the velocities of the two balls participating in the collision immediately after the collision. Having that, you should be able to figure out the velocity of the system's CM.
Thank you
  • · Replies 20 ·
