The Relationship Between Function and Ordering Relation
  • Context: High School
  • Thread starter Thread starter littlemathquark
The discussion revolves around the conditions under which a function can induce an ordering relation on its domain, specifically focusing on partial and total orders. Participants explore the implications of order-preserving functions and the nuances of defining order relations based on mappings between sets.
  • Some participants propose that a function must be compatible with the ordering defined on the codomain to induce an ordering relation on its domain.
  • Others argue that the term "order inducing function" is misleading, suggesting that functions can only be order-preserving or order-reversing, and question the notion of an ordering solely created by a function.
  • A participant questions whether the discussion is about the conditions under which a function can define an order on its domain based on an existing order on the codomain.
  • Some participants assert that given an ordered set, a function can define an order on its domain based on the order of its codomain, but clarify that this applies only to the image of the function, not the entire domain.
  • Concerns are raised about the precision of language used in the discussion, emphasizing the need to distinguish between the entire domain and the image of the function.
  • One participant highlights the concept of pulling back an order relation, suggesting that the order on the domain is derived from the order on the codomain through the function.
Participants express differing views on the terminology and conditions necessary for a function to induce an ordering relation. There is no consensus on the definitions or implications of the terms used, leading to an unresolved discussion.
Participants note the importance of clearly stating assumptions about the domains and codomains involved, as well as the need for precision in the definitions of functions and their relationships to orderings.
littlemathquark
TL;DR
What is the necessary and sufficient condition for a function to induce an ordering relation (partial or total)?
I think, the necessary and sufficient condition for a function to induce an ordering relation (specifically a partial or total order) on its domain is that it must be compatible with the ordering defined on the codomain (i.e., it must be order-preserving).
How can we express this necessary and sufficient condition more clearly? Thank you.
The term of an order inducing function doesn't make much sense. We have order preserving functions, and order reversing functions if domain and codomain allow an ordering. But what would be an ordering solely created by a function? If a domain is ordered, say ##\mathbb{N},## then any function ##f\, : \,\mathbb{N}\to \mathbb{N}## defines another order, simply by defining ##f(n)< f(n+1).## You can get any order on ##\mathbb{N}## this way since all permutations can be ##f.##
Is the question: if &lt;_Y is an order on Y, what conditions must f: X \to Y satisfy in order that we can define &lt;_X via f(x) &lt;_Y f(y) \Leftrightarrow x &lt;_X y?
littlemathquark said:
TL;DR Summary: What is the necessary and sufficient condition for a function to induce an ordering relation (partial or total)?
For one, your function would have to be defined in ordered domains and codomains, I would guess, with a nice -enough relationship between the two orderings.
I think that is true:
Let (S,⪯) be an ordered set. Then given any set X and a function f:X→S , we can define an order ##⪯_X## on X by ##x_1⪯_Xx_2## if and only if ##f(x_1)⪯f(x_2)##
Only on ##f^{-1}(S)## not on entirely ##X.##
X is the domain of f : X \to S. By definition, each element x \in X has a unique image f(x) \in S.
This discussion is about precision and wording. The assumption that ##X## is the entire domain has to be stated, in my opinion. People speak of real functions and ##x\mapsto 1/x## at the same time without distinguishing the two. If we continue to be as sloppy as the thread's start already is, then this entire discussion becomes even more ridiculous. Moreover, the example in post #5 does not "induce" an order by the function ##f##, it pulls back an order!
This thread is along the pattern: choose a subject everybody has something to say about, be as vague as possible in your question, occasionally contribute a few crumbs, and enjoy the resulting nonsense.
It seems the issue here of the pullback of an order relation. Then we say ##x_1##~##x_2## iff(def.) ##f(x_1)##~##f(x_2)##. Given a set S with given structure and a bijection ##f: X\rightarrow S##, the structure can be pulled back into ## X##.
  • · Replies 17 ·
  • · Replies 41 ·
