The Spinning Siren - a perceptual brain teaser
  • Thread starter Thread starter nonzero
    Brain Spinning
The discussion revolves around the perceptual phenomenon of a spinning figure, often referred to as the "Spinning Siren," and how individuals perceive her rotation as either clockwise or counterclockwise. Participants explore the underlying mechanisms of perception, including visual cues and brain processing, while considering the implications of two-dimensional representations.
  • Some participants note that many individuals can only perceive the figure spinning in one direction, suggesting a difficulty in switching mental perspectives.
  • One participant proposes that the illusion may arise from a mismatch in the timing of visual information received by each eye, potentially influenced by muscle strength differences.
  • Another participant points out the limitations of the animated GIF, indicating that the animation does not switch directions but may have a hiccup that affects perception.
  • A participant suggests that the perception of rotation is determined by the brain rather than the eyes, using a hypothetical example of a line tracing a cone to illustrate this point.
  • Some participants speculate that the shadow of the figure may influence perception, with one noting that covering the shadow changes their perception of the rotation direction.
  • One participant claims they can mentally switch the direction of rotation at will, while another finds it easier to switch perspectives when focusing on specific parts of the figure.
  • Several participants express skepticism about the validity of the illusion, citing the shadow's movement as a conflicting cue that affects their interpretation of the figure's rotation.
  • One participant describes an experience where they perceive different rotations based on which parts of the figure are visible, indicating variability in perception based on visual focus.
Participants express a range of views on the nature of the illusion, with no consensus on the mechanisms behind the perception of rotation. Some agree that the shadow plays a role, while others argue against the validity of the illusion based on visual information.
Participants mention various assumptions about visual perception, including the influence of eye dominance and the role of shadows, but these remain unresolved and are subject to individual interpretation.
nonzero
The trick is to see this lady spinning in each direction: clockwise or counterclockwise. Most will see it orienting in one direction only. It's difficult to switch it in our minds. For many the task will be impossible.
http://mindbluff.com/clockwise.htm
Okay assuming it's not just a simple case of switching the direction of the spin ever so often, I reckon it's probably just a matter of two things being slightly out of sinc, either the frequency of spin of the lady and her shadow, or a difference in strength between the muscles in your right and left eye.
The image is an animated GIF with only 34 frames, so it's not switching (although there does seem to be a slight hiccup between the 34th and 1st frame).
I'm not sure what you mean-- if that were true, wouldn't you expect to see one version if you closed your left eye, and another version if you closed your right eye?
DaveE
A three dimensional skater can turn clockwise or counter-clockwise. However this skater is two dimensional. The direction she turns in is determined not by your eyes, for they can only see a two dimensional image, but by your brain. Imagine, instead of a human figure, an oblique line sweeping out a cone with the lower endpoint stationary. Now make a two dimensional flip book image of it. In the flip book, the upper endpoint will trace a line going alternately 'left to right' and 'right to left' in a plane. There is no question of clockwise or counter-clockwise there. Would the same illusion occur?
I think it would have something to do with one eye seeing her foot let's say, arrive slightly later on the right than the other eye does and your brain quickly switching between using (the information from) your dominant eye and the other eye when your dominant eye gets tired, so you would need to look through both eyes to get the effect.
I'm really just guessing here, but my feeling is that it would be a similar effect to what would happen when you watch a spinning wheel for a long time, after a while it looks like the spokes are rotating backwards. I'm guessing there would be an analogous effect for any such periodic motion where you're watching it for a decent amount of time. Of course if you still see the effect looking through only one eye that would blow that theory out of the water :)
I can mentally flip her direction of rotation pretty much at will - just don't "buy in" to the first direction your brain perceives, and that should help.
Okay just saw it switch looking through just one eye ;) so that theory is bogus. I seem to find it easier to switch the rotation when I look at her foot and the shadow of her foot at the same time, I can't help wondering if the shadow is playing some part here? Perhaps in simplifying the image in my mind to something similar to what you describe jimmysynder.
This "illusion" is also flawed due to the shadow in the forefront, moving right to left, which would be moving in the opposite direction if she were even able to spin counter-clockwise.
The only way the acclaimed "left brain" would be able to see her spinning CCW is if they ignored available information.
Placing my hand over the shadow, I can indeed see her spinning CCW. But, sorry, my makes use of all available info, so, given the visual information provided in the "illusion," she's spinning CW.
If I cover up the silhouette and just look at the shadow underneath then look at her, I see her spinning CCW. If I cover up the entire silhouette and shadow except for the right side of the picture so that you can only see her arm poke in and out, I see her going CW.
I think that it's just fine. When seeing her go CCW, your brain thinks the shadow is caused because she becomes closer to the ground, which causes the shadow to come into view.
If you put your fingers over the body part and just look at the top of the head and shadow part, in my view the head is going a different way than the feet...
  • · Replies 27 ·
  • · Replies 24 ·
  • · Replies 135 ·
25K
16K
9K
