Solving the Mystery of Negative Square Roots
The discussion revolves around the evaluation of the expression √(-1)², leading to confusion about the correct interpretation and results. One approach suggests that taking the square of -1 first yields 1, while another method implies that replacing the radical with an exponent leads to -1. Participants clarify that the expression should be interpreted as √((-1)²), which simplifies to 1, emphasizing that the square root function returns the principal (positive) root. They also highlight that exponentiation rules do not apply uniformly to negative bases, particularly in the context of complex numbers. Ultimately, the consensus is that the correct answer is 1, and the confusion stems from misapplying exponentiation laws.
ViolentCorpse
Hello everyone,
What is the square root of a square of a negative number equal to? For example: \sqrt{-1}^{2}
It seems there are two possible ways of doing this, the problem is that I am getting two different answers using these two approaches i.e; We can first take the square of -1 and then take square root of the square of -1. This gives 1 as the answer. On the other hand, if we replace the radical sign by 1/2 as the exponent, we should then just be left with -1 as the answer. The correct answer, I think, is +1, but I can't figure out why there's an apparent contradiction...
Please help me understand where and why I am wrong.
Thank you!
Mathematics news on Phys.org
ViolentCorpse said:
Hello everyone,
As written, most mathematicians would (probably*) parse that as ##(\sqrt{-1})^2##. The square root evaluates to either i or -i depending on where your branch cut is, but they both square to -1.
*: It's ambiguous though.
With complex numbers your assumptions of exponentiation derived from the reals breaks down. In this case you are assuming ##(a^{b})^c = (a^c)^b##, and this is simply not true. Further ##(a^b)^c \neq a^{bc}## in general.
Likes 1 person
I find your notation unclear.
Do you mean: a: \sqrt{(-1)^{2}} b: (\sqrt{-1})^{2}
ViolentCorpse said:
Hello everyone,
Thank you!
Your notation is ambiguous, as others pointed out, but your verbal explanation of the problem is clear. You want to evaluate ##\sqrt{(-1)^2}## or ##{((-1)^2)}^\frac{1}{2}##.
In essence, they're the same thing. Both exponentiation operations are of equal precedence, so you work from inside out. You're left with ##\sqrt{1}## or ##{1}^\frac{1}{2}##. Those are just different ways of writing the same thing. The usual implication of exponentiation to a fractional power is the extraction of the principal root, which is the unique positive value, if it exists. In this case, that's simply ##1##.
Doing it the second way, you might be tempted to use the law of exponents ##(a^b)^c = a^{bc}## to cancel the ##2## and the ##\frac{1}{2}##, but this would be wrong. That law only applies (without qualification) when ##a## is non-negative.
Likes 1 person
remember that:
\sqrt{x^{2}}=|x|
not x.
Likes 1 person
Based on what VC described rather than the notation used, this is the problem: ##\sqrt{(-1)^2}##. This expression simplifies to 1.
Likes 1 person
Actually, the notation used was clear and unambiguous, but did not agree with his description.
Likes 1 person
This is what I meant: ##\sqrt{(-1)^2}##.
I'm sorry for the ambiguity guys. I tried putting the parentheses around -1 before, but the code broke down for some reason, so I removed it.
I think the greatest gap in my understanding was that I didn't know that the rule (a^{b})^{c} = a^{bc} couldn't be applied for a<0 (still a bit confused about this point. Isn't (-2^{3})^{2} = (-2)^{6}?
I knew that \sqrt{x}^{2}=\left|x\right|, but it felt like this was inconsistent with the former rule (law of exponents), thanks to my ignorance. :redface:
Thank you so much, all of you! I seriously appreciate your help more than you probably know. :smile:
  • · Replies 45 ·
  • · Replies 19 ·
  • · Replies 16 ·
