The time in minutes, it takes to reboot a certain system
  • Level: Graduate
  • Thread starter Thread starter TomJerry
    System Time
1 reply · 3K views
TomJerry
Question:
The time in minutes , it takes to reboot a certain system is continuous random variable with density.
f(x) = C(10-x^2), 0<= x <=10 ;
= 0 , other wise
i) compute C
ii)Obtain the probability that it takes between 1 and 2 minutes to reboot.
Solution :
i)
f(x) = [tex]\int_{0}^{10}[/tex] C(10-x^2) dx =
C = - 3 /700 [Is this correct]
ii)
[tex]\int_{0}^{10}[/tex] f(x) -[[tex]\int_{0}^{1}[/tex] f(x) + [tex]\int_{2}^{10}[/tex] f(x)]
[Is this correct]
I agree with your answer to i), although technically the given function is not a probability density function. In that case, namely, it should be non-negative everywhere, which [itex]-\frac{3}{700} (10 - x^2)[/itex] is not. Are you sure that the 10 is not supposed to be a 100?
For ii), your expression is correct, but it is a bit cumbersome.
Can you prove that what you wrote is actually the same as
[tex]\int_1^2 f(x) \, dx[/tex] ?
