Integral of √((1+x²)/(1-x²))
  • Thread starter Thread starter pierce15
    Antiderivative
14 replies · 3K views
pierce15
1. The problem, the whole problem, and nothing but the problem
$$ \int \sqrt{\frac{1+x^2}{1-x^2}} dx $$
I tried a partial fraction decomp, but this obviously didn't get me very far because this isn't a rational function. Is there some kind of ingenious substitution applicable here?
I don't see any way to get an antiderivative. And Wolfram Alpha says it's an elliptic integral. I don't disagree. If it's a definite integral there might be a trick. Is that the whole problem?
... I made it up
I've changed the problem to the following:
$$ \int \sqrt{\frac{1+x}{1-x}} dx $$
According to wolfram, this does have a (nasty) elementary antiderivative. Any thoughts?
piercebeatz said:
... I made it up
You are making up HARD PROBLEMS.
Sorry for adding new detail to a previous post by the way, I just remembered that that's a big no-no
Making your own integrals isn't a good idea because you tend not to know if you can solve them. For example: [itex]\int e^{x^{2}} dx[/itex]
The new integral you made up is solvable however. Do a u substitution.
piercebeatz said:
... I made it up
Substitute something that would make that square root on the denominator much easier to deal with (or eliminate).
How about the substitution ## x = -2u - u^2##, ##dx = -2 - 2u##
$$ \int \sqrt{ \frac{1 - 2u-u^2}{1+2u + u^2} } (-2-2u) \, du $$
$$ -2 \int \frac{ \sqrt{1-2u-u^2} }{1+u}(1+u) \, du $$
$$ -2 \int \sqrt{1-2u-u^2} \, du$$
Alright, that looks fairly simple, but I'm blanking as to how I should deal with it.
I'd say complete the square and then use a trig substitution.
Why not ##x = 1 - u^2##?
Alright, I completed the square, changing ##1-2u-u^2## to ## 2-(1+u)^2##.
$$ -2\int \sqrt{2-(1+u)^2} \, du $$
$$1+u = \sqrt{2} \sin\theta, \quad du = \sqrt{2} \cos \theta \, d\theta $$
$$ -2\sqrt{2} \int \cos \theta \sqrt{2-2 \sin^2\theta} \, d\theta $$
$$ -4 \int \cos \theta \sqrt{1-\sin^2\theta} \, d\theta $$
$$ v = \sin \theta, \quad dv = \cos \theta \, d\theta$$
$$ -4 \int 1 - v^2 \, dv $$
$$ -4( v - v^3/3) $$
$$ 4(v^3/3 - v) $$
Before I go back and perform the various substitutions, is that correct?
That would have truly been a wise choice
$$ 4(v^3/3 - v) $$
Isn't 1 - sin2θ just cos2θ?
-.- yes
$$ -4 \int \cos^2 \theta \, d\theta $$
$$ -4 \int \frac{1+\cos(2\theta)}{2} d\theta $$
$$ -2\Big(\theta + \int \cos(2\theta) d\theta \Big)$$
$$ -2(\theta + \frac{ \sin(2\theta)}{2}) $$
$$ - \sin(2\theta) -2\theta $$
