The uncertainty when measuring time
The discussion centers on the inherent uncertainty in measuring time, emphasizing that all measurements possess some degree of uncertainty. Current technology allows time measurement to an accuracy of 1 part in 4 trillion, primarily using strontium atomic clocks, which are the most precise timebases available. The conversation highlights the challenges in synchronizing events with measurement devices, illustrating that while we can measure the passage of time, we cannot measure time itself definitively.
  • Understanding of atomic clocks, specifically strontium atomic clocks
  • Familiarity with the concept of measurement uncertainty
  • Basic knowledge of time measurement techniques
  • Awareness of the implications of human reaction times in timing events
  • Research the specifications and functioning of strontium atomic clocks
  • Explore the concept of measurement uncertainty in scientific contexts
  • Investigate the implications of the faster-than-light neutrino anomaly
  • Learn about advanced time measurement techniques and their limitations
Scientists, physicists, and anyone interested in the precision of time measurement and the philosophical implications of measuring time versus the passage of time.
Quarlep
Does any uncertainty when measuring time?
Can we measure time definitely(hundred percent correct)
All measurements have uncertainty. Currently we can measure time to within 1 part in 4000 trillion. So it is pretty accurate but it will never be perfectly certain.
You can measure the time between two events quite accurately within a clock but getting the events "to the clock" without messing up the timing can be problematic. As an analogy... A stopwatch can be accurate to 100th of a second but the human sending the start/stop signal to the stopwatch may have much slower reaction and operation times.
Interesting to read some of the issues involved in trying to measure the time it takes Neutrinos to travel 450 miles..
http://en.wikipedia.org/wiki/Faster-than-light_neutrino_anomaly
You can't "measure" time.
We can only measure the passage of time, but not time itself.
The limit of measurement is the limit by the "clock" or timebase you use and the mechanism buy which you tag the start and stop of an event. Right now the strontium atomic clock is the most accurate timebase we have. You might do a search for that if you want actual numbers.
Thanks
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 32 ·
  • · Replies 18 ·
  • · Replies 48 ·
