"The wavefunction never collapses"
  • Context: Undergrad
  • Thread starter Thread starter sevensages
  • #31
DrChinese said:
Regardless of one's objections (e.g. "the measurement problem") to generic Copenhagen-type QM:
The most obvious problem with MWI is that it is falsified by observation. Much like the assertions that the Earth is flat, or angels exist, or so forth. If there are other branches, where are they? I don't see any, no one ever has.
What is the point of saying that MWI is falsified while Copenhagen is not?
These interpretations correspond in the sense that they can explain the same experimental results. In this sense, MWI is like an analytical extension of Copenhagen (I'm speaking in an analogous sense).
  • #32
Roberto Pavani said:
This is a brutal underestimate
Not necessarily. You are assuming that every single Planck scale spacetime "cell" is decohered from every other. But that's not the case. The MWI does not say that every single quantum degree of freedom is branching at every Planck time. It only says branching occurs when an interaction takes place that results in decoherence, and the only branches are the decohered ones. So, for example, in a Schrodinger's Cat experiment, there would be only two branches, "cat alive" and "cat dead", since those are the two decohered outcomes. There would not be a different branch for every single microscale interaction between the cat's atoms, since those don't decohere separate branches; they just cause the cat to behave classically in the two branches caused by the experiment, "alive" and "dead".
  • #33
Please do not pursue this subthread further. What I said in post #27 is all that can be said about it in this forum.
  • #34
My estimate in #29 uses the same logic as the standard vacuum energy calculation that gives the 10¹²⁰ cosmological constant problem: counting quantum modes up to the Planck cutoff. If that counting is wrong for branching, as your correction in #32 suggests, could it be wrong for vacuum energy too? That would be interesting in itself. If instead the vacuum energy counting is legitimate, then perhaps my estimate isn't as far off as it seems.
I'm probably missing something here, but I'd be curious to understand where the two calculations diverge, if they do.
  • #35
If it is, I don't think it would be for the same reason, since the vacuum energy counting assumes a single universe, not many worlds. It's simply a comparison of the simple, obvious way to calculate the ground state energy of the QFT vacuum with a Planck scale cutoff, with the value we actually observe based on the acceleration of the cosmological expansion. That ground state energy is the energy of a single state in a single universe.
  • #36
Dale said:
I have wondered about this. Are they really mutually incompatible? They all share the same math and the same experimental predictions. So nature doesn’t seem to view them as incompatible.
At our current understanding of QM, that is true. Still, some think that with future research, it may be possible to experimentally distinguish between them; for example, the experimental confirmation of Bell's theorem by Alain Aspect and others rules out a whole class of interpretations, namely those with local hidden variables. Also, to some extent, the difference between interpretations is a matter of philosophical preference rather than anything objective. Many, including me, think the difference between modern versions of Many Worlds and so-called Dechorent Histories is just the semantic difference between potentially real and actually real. See David Wallace's excellent book, The Emergent Multiverse:
https://www.amazon.com.au/Emergent-Multiverse-Quantum-According-Interpretation/dp/0199546967
Contrast it to Decoherent Histories, as explained here:
https://quantum.phys.cmu.edu/CHS/histories.html.
It must also be mentioned that ordinary QM is just an approximation to a deeper theory called Quantum Field Theory (QFT), which incorporates Special Relativity. Interestingly,y when the non-relativistic limit of QFT is taken, the result is not ordinary QM. This means that strictly speaking, interpretations of ordinary QM are just intellectual exercises. What is needed are interpretations of QFT. For one such realistic interpretation (it has a few issues, no need to go into here), see:
https://www.amazon.com.au/Fields-Their-Quanta-Quantum-Foundations/dp/303172612X/ref=tmm_hrd_swatch_0
Somewhat pricey, but it does give a different take (and one I basically agree with) than found in popular accounts.
Thanks
Bill
  • #37
martinbn said:
Why should MWI derive it? Why shouldn't every interpretation?
Well, there is Gleason's Theorem.
However, Many World proponents seem to favour a betting-type argument, possibly because they don't want to use Gleason's non-contextuality assumption.
Anyway, this has been examined before on this forum:
Thanks
Bill
  • #38
A local hidden variable theory isn't an interpretation of QM, it's a different theory--because it doesn't (and can't) predict Bell inequality violations, and QM does. What experimentally confirming the QM predictions of Bell inequality violations did was to dash the hopes of people who were clinging to the idea that QM might end up not being quite right in this regime, and some kind of more classical-like theory would win out. No such luck.
  • Love
  • #39
PeterDonis said:
No, you're seeing an objection that many others (myself included) also see to the MWI.
Same here.
I am not convinced of the betting argument either.
To be fair, anyone reading this needs to see the argument and its various forms and decide for themselves. I personally stick with Gleason.
Thanks
Bill
  • #40
Gleason's Theorem doesn't depend on any particular interpretation of QM: it just says that, given the basic math of QM, if you want to compute something from the quantum state that has the desired properties of a "probability", you have to use the Born rule (more precisely, you have to compute ##\text{tr} \rho A## where ##\rho## is the density operator for the state and ##A## is whatever observable you're interested in). The theorem says nothing about what the thing you compute that has the desired properties of a "probability" means physically. That's what has to be filled in by QM interpretations, and different ones of course fill it in very differently. But in this respect the MWI is not in a different position from any other interpretation--it has its own way of doing the filling in, but so do all the other interpretations.
  • Love
  • #41
And given that infinitely many quantum events have occurred since the beginning of the universe, why do we always find ourselves in the branch where statistics match the Born rule?
Why is this any different than very large fluctuations being observed in local gas pressure in statistical mechanics? All micro-states are possible. We just don’t observe ones like these because they are just too rare.
  • #42
Although I agree with the general gist of statements made in this post (my read: decoherence drives branching, we don't branch off of every quantum d.o.f.), I think saying there's just *two* branches for Schrodinger's cat is oversimplifying things. Decoherence is not a sharp line. You still have to define what is the sub system and what is the environment the subsystem gets entangled with. Further, the decoherence typically has a time scale through which the off-diagonal terms decay. It's not clear to me how you set a threshold for when a "full decoherence" has even happened.
Lastly of course, there's at least macroscopic states like "detector has clicked", "poison has entered the blood stream", "cat has gone unconscious" etc...
I think measuring the number of branches in MWI is quite tricky...
Further, here is a (genuine) question: do we even know MWI has a finite number of branches? I don't know if even this question is settled yet?
  • #43
I am not a fan of many worlds, but the fact that the other branches have never been seen does not disprove it. It predicts that as part of the theory.
In my opinion, for what it is worth, it's unnecessarily extravagant. If you are attracted to MW, Decoherent Histories treats all possible outcomes on equal footing, but only one is real. The classical world is then emergent by coarse-graining:
https://www.sciencenews.org/blog/context/gell-mann-hartle-spin-quantum-narrative-about-reality
Both can be generalised to QFT, which I believe is important.
Thanks
Bill
  • #44
We would generally regard QFT as only an effective field theory that approximates some deeper theory as well. QFT still suffers from a whole host of issues -- there's a millennium prize problem just to put one type of QFT on solid mathematical footing.
  • Love
  • #45
Indeed:
Thanks
Bill
  • #46
Indeed.
That is the argument against the literal realistic interpretation of QFT as found in Art Hobson's book, Fields and Their Quanta. However, the very reality of particles becomes an issue: in QFT, they are 'knots' in the quantum field. If the field is not real - gurgle, gurgle.
To the OP, there are still unresolved issues in the foundations of QFT. Ordinary QM, I am not worried about, since it is not the limiting case of QFT, so all that is needed to show it is a reasonable approximation to QFT, which it is. Start a new thread if you are interested in how to do that.
Thanks
Bill
  • #47
The premise of the thought experiment is that "alive" and "dead" are two distinct, macroscopically distinguishable cat states, and that there is no third one. Of course neither of these cat states are simple, and of course the cat is not the entire universe. But the premise of the thought experiment is that there are no other macroscopically distinguishable outcomes: just "poison released, cat dead" and "poison not released, cat alive".
Not really, no. You don't need to have an exact accounting of which atoms are part of the cat and which are part of the environment in order to observe whether the cat is alive or dead.
The heuristic answer we have now is "when macroscopic outcomes can be irreversibly distinguished". In this case, when we can tell whether the cat is alive or dead. Of course it takes a finite time for the poison, if it's released, to kill the cat. But by that time the "poison released" vs. "poison not released" decoherence has already happened; the decoherence time for that is much shorter than the time it takes for a poisoned cat to die. So actually, by the time the cat dies, in the branch where it does, a macroscopically distinguishable outcome has already occurred--the cat dying is just a further classical consequence of it.
Which is how the MWI defines branching. See above.
I should note that there is another reason for expecting there to be more than two branches in this thought experiment that has nothing to do with any of the above, at least if we add a clock to the setup: if the clock records the time when the radioactive atom decays and causes the poison to be released, there will be a branch for each possible time that could have happened (heuristically, the granularity will be the accuracy of the clock's readings--is it accurate to 1 second, 1 microsecond, 1 nanosecond, etc.). I don't know if this angle has been considered in the literature.
  • #48
In the general case, no, because not all observables have a discrete spectrum, and at least on its face, the math for observables with a continuous spectrum leads to a continuous infinity of branches. And even with observables that have a discrete spectrum, it might have a countably infinite number of possible outcomes (for example, energy levels of bound states of electrons in an atom).
  • #49
Didn't you say that after message 27 we couldn't talk about this anymore and that everything had already been said?
  • #50
No. I said that about the claim that the MWI has been falsified. That's not what's being discussed in the post you quoted.
  • #51
Following #48: so the number of branches can be a continuous infinity. My estimate of 2^(10²⁴⁵) in #29 was potentially wrong, but still an underestimate.
  • · Replies 69 ·
  • · Replies 32 ·
