Theoretical Framework for Hyperdrive Dynamics: The Three Laws of Hyper
Denys Kovalchuk
TL;DR
Although this is an assumption, perhaps in the future it can be verified.
Hello everyone,
I am a 9th-grade student from Ukraine with a deep passion for theoretical physics and science fiction (especially Star Wars). Since we currently lack the technology to experimentally test higher-dimensional travel, I have spent some time developing a logical, mathematical hypothesis on how matter might behave when transitioning into and traveling through hyperspace (specifically assuming a 6-dimensional or 12-dimensional framework).
I wanted to share my Three Laws of Hyperspace to get your feedback on the analytical logic behind the variables, dependencies, and constants.
Here is the structured framework:
THE THREE LAWS OF HYPERSPACE
A theoretical model governing the movement of 3D matter at superluminal speeds within a higher-dimensional medium.
THE FIRST LAW: The Law of Material Transition
This law defines the physical engineering conditions required for a three-dimensional object to breach the speed of light barrier and undergo a phase transition into hyperspace.
1. Engineering Formula (Launch Calculation):
Y = (M * D * S) / t
2. Navigational Formula (Initial Stability Margin):
T = (Y * (D * S - V)) / (K * M)
Where:
Y (Vector) = The required hyperdrive power output to rupture 3D spacetime.
T (Hyper-period) = The safe duration of the object's stay inside hyperspace (measured in days).
M (Mass) = The total mass of the object in normal space.
D (Kerns) = The material density and structural strength of the ship's hull.
S (Monolis) = The structural integrity coefficient (e.g., deflector shield grid efficiency).
V (Vacuoles) = The volume of internal empty spaces (habitable zones, cargo bays).
K (Resistance) = The gravitational background constant of the medium (escalates near stars or black holes).
t (Activation Time) = The duration of the drive's engine spool-up and acceleration during transition.
Physical Essence: The First Law correlates the ship's mass and structural resilience with the required power output. A heavier mass (M) or higher hull durability (D * S) demands exponentially more energy (Y) to force a transition.
THE SECOND LAW: The Law of Pure Medium Geometry
This law describes the behavior and stability of 3D matter inside the hyperspace medium after the transition is complete. It is derived by mathematically combining the equations of the First Law.
The Unified Formula:
T = (D * S * (D * S - V)) / (t * K)
Physical States of the Object in Hyperspace:
T > 0: The object is stable. Safe travel is permitted within the calculated timeframe.
T = 0: The Critical Rupture Point. Triggers an instantaneous violent exit or absolute structural decay under the medium's pressure.
T < 0: Hyper-incompatibility State. Attempting transition or flight results in an immediate gravitational collapse of local spacetime around the object.
Physical Essence (The Mass Paradox): Once inside hyperspace, the raw mass (M) of the object cancels out mathematically and ceases to affect structural stability. The safe travel window (T) relies entirely on the quality of materials ((D * S)^2), the volume of internal vacuoles (V), local gravitational anomalies (K), and the initial transition velocity (t).
THE THIRD LAW: The Law of Decoherence and Deceleration (The Exit)
This law determines the criteria for an object to safely exit the higher dimension and reintegrate into normal 3D spacetime without obliterating itself or its arrival coordinates via residual energy discharge.
The Safe Return Formula:
E_out = (M * delta_v^2) / (D * S * T_rem)
Where:
E_out (Hyper-burst) = The quantity of kinetic and relativistic energy discharged as thermal/radiation emissions upon exit. It must not exceed the hull's survival threshold.
delta_v (Delta Velocity) = The variance between the virtual velocity in hyperspace and the real velocity upon re-entering normal space.
T_rem (Remaining Hyper-period) = The safety margin of time left on the clock according to the Second Law at the moment of exit.
Core Rules of Extraction:
The Time Margin Rule: If an exit is attempted as T_{rem} \to 0, the denominator approaches zero, causing the energy burst (E_{out}) to spike toward infinity, instantly incinerating the vessel. Exits must be executed prematurely.
The Mass Deceleration Rule: The heavier the vessel (M), the more it must decrease its virtual velocity before dropping out of hyperspace. Otherwise, the massive energy discharge (E_{out}) could scorch or disrupt the planetary or stellar system at the destination.
I would love to hear your thoughts on this! Does the mathematical interplay between these variables make sense from a theoretical standpoint? How would you modify these equations to account for concepts like time dilation or cosmic radiation shielding?
  • · Replies 28 ·
  • · Replies 26 ·
