Theoretical Magnetic Propulsion
The discussion centers on the theoretical application of strong electromagnetic fields for magnetic propulsion. It emphasizes the necessity of quickly activating and deactivating the electromagnetic field to prevent the object from exerting a force back on the source. The concept requires the object to be positioned within the "far-field" region of the transmitter, which is crucial for effective propulsion without immediate counteracting forces. This approach could revolutionize propulsion methods by utilizing electromagnetic radiation as a driving force.
  • Understanding of electromagnetic fields and their properties
  • Knowledge of magnetic propulsion concepts
  • Familiarity with the far-field and near-field regions in electromagnetism
  • Basic principles of electromagnetic radiation transmission
  • Research the principles of electromagnetic field manipulation
  • Explore existing magnetic propulsion technologies and their limitations
  • Study the effects of distance on electromagnetic force application
  • Investigate the design and function of electromagnetic transmitters
Physicists, engineers, and researchers interested in advanced propulsion systems, particularly those exploring the applications of electromagnetic fields in transportation technologies.
Layne Burgess
I was curious to the effects of a strong electromagnetic field applied to an object at distance. The field must be able to quickly activate and deactivate in order to account for the distance traveled towards the object as to eliminate the force applied to the source of the field by the object. I do apologize If that didn't make sense, basically if you move a object with a magnet you can feel the force applied by the object. What would happen if you could apply the force to the object and then turn off the source of the magnetic field before the object had a chance to return the force?
In order for this to happen, the object would need to be located a large distance from the source. It would necessarily be located within the "far-field" region of the transmitter. I say transmitter because that's essentially what the source would become; a transmitter for electromagnetic radiation.
  • · Replies 20 ·
10K
