There's a chopstick on my hand. I need to find the 'angles'.
  • Thread starter Thread starter lgmcben
    Angles hand
The discussion focuses on simulating the angular acceleration of a chopstick falling onto a hand, incorporating the effects of the hand's movement. The key takeaway is that the hand exerts a force that influences both linear acceleration and torque, which must be accounted for in the simulation. The torque can be calculated using the equation F = ma, where F is the force exerted by the hand, m is the mass of the chopstick, and a is the hand's acceleration along the specified axis. Additionally, the center of mass of the chopstick must be considered when determining the torque if the pivot point is not at the center.
  • Understanding of angular acceleration and torque
  • Familiarity with Newton's second law (F = ma)
  • Knowledge of simulation programming techniques
  • Basic principles of rigid body dynamics
  • Research how to calculate torque about the center of mass in rigid bodies
  • Learn about simulating angular motion in physics engines
  • Explore the effects of varying pivot points on torque calculations
  • Investigate the impact of multi-axis acceleration on angular dynamics
Physics students, simulation developers, and anyone interested in the dynamics of rigid body motion and angular acceleration.
lgmcben
Known:
- Mass of the chopstick
- Gravity
So the alpha(angular acceleration) can be found
By knowing angular acceleration, I successfully wrote a program that simulate a chopstick falling onto my hand. But all of this is assuming my hand didn't move at all. Currently in my simulation, only the gravitational force affect the angle change (angular acceleration).
My question:
How my hand affect the angular acceleration?
I have these data:
- My hand's acceleration in x, y and z axis.
Welcome to PF!
Hi lgmcben! Welcome to PF! :wink:
Your hand will exert a force F, which wiill increase the linear acceleration by F/m, and will also add a torque. :smile:
Hi. Thank you for your answer. =)
I'm sorry I forgot to mention that I want to omit any linear translation in this simulator ^_^; I only need to simulate the angular-related translations.
I have one more question:
Does this torque equal to
Where
F = ma
and
m = mass of the chopstick
a = acceleration of my hand in x axis? (if x, y and z axis is too much, then let's talk about only x-axis for now)
Thank you again!
Yes it does equal to the above specified equation. However, you will need to consider torquing about the centre of mass in the chopsticks if the pivot points are anything except the middle of the chopsticks (assuming mass to be equally distributed and the chopsticks to be rectangular prisms)
  • · Replies 18 ·
10K
