Thermodynamics physics help
A constant-volume gas thermometer shows a pressure of 0.900 atm at -50.0ºC and 1.510 atm at 100.0ºC. To find temperatures for pressures of 1.000 atm and 1.200 atm, the ideal gas law is applied using the relationship P/T = constant. Converting the temperatures to Kelvin yields consistent results, with calculations showing approximately -25.72ºC for 1.000 atm and -26.1ºC for 1.200 atm. The slight differences in temperature results are attributed to rounding and significant figures. Accurate application of the gas laws confirms the temperatures are effectively the same within the limits of measurement.
jbrookins3
a constant-volume gas thermometer has a pressure reading of 0.900 atm at -50.0ºC and a reading of 1.510 atm at 100.0ºC. What temperature is associated with: a) a pressure of 1.000 atm and b) 1.200 atm?
well I am not sure where to start i thought i should use PV=nRT and i could use a proportion PV/T=PV/T and with the V constant it would just be P/T=P/T but the 2 pressures and temps in the problem don't follow that
if i just knew what direction to go in i should be able to solve the problem
P/T=P/T is the right approach. The ideal gas laws always use temperatures in Kelvins. (That prevents you getting zeros in denominators or negative pressures and volumes). If you convert -50.0ºC and 100.0ºC to K, do you get consistent results?
Since P/T = constant, you should be able to use either P/T value to get T at P = 1 atm.
for part a:
if i convert the temp to K and use P/T=P/T with both initial p/t i get
.900/223=1.00/T t=247.78K or -25.72C
1.510/373=1.00/T T=247.02K or 25.98C
is the difference just do to some rounding in the initial 2 sets of pressures and temps?
That is the most likely reason I'd say.
jbrookins3 said:
for part a:
If you follow the rules of significant figures, the two temperatures round to 248 K and 247.0K. Those convert to -25 C and -26.1 C. Given the interpretation that values are known within 1 of the final digit, those numbers are "the same".
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
