How Does Temperature Affect pKa Values in Buffer Preparations?
  • Thread starter Thread starter CSA
    Thermodynamics
This discussion focuses on the preparation of phosphate and bicarbonate buffers at pH 7.4, emphasizing the importance of accurately determining the acid and conjugate base ratios while accounting for temperature effects on pKa values. The user seeks clarification on the thermodynamic pKa and apparent pKa, with the consensus that apparent pKa values, which adjust for ionic strength, are more relevant for practical calculations. It is noted that temperature effects on pKa are minimal compared to ionic strength variations, which significantly impact Ka values in concentrated solutions.
  • Understanding of buffer chemistry and the Henderson-Hasselbalch equation
  • Familiarity with pKa, Ka, and their thermodynamic implications
  • Knowledge of ionic strength and its effects on chemical equilibria
  • Basic principles of the Debye-Hückel theory
  • Research the use of buffer calculators that account for both temperature and ionic strength
  • Learn about the Debye-Hückel theory and its application in buffer solutions
  • Explore the differences between thermodynamic pKa and apparent pKa in detail
  • Investigate the impact of ionic strength on buffer capacity and pH stability
Researchers, chemists, and laboratory technicians involved in buffer preparation and pH optimization, particularly in biochemical and analytical applications.
CSA
I am preparing a phosphate and a bicarbonate buffer at pH 7.4. I am not using the tradition of making a "rough" buffer and then adjusting the pH to the desired value as I want to target a certain value of osmolarity in both buffers. As such I just want to do all calculations beforehand to determine the exact amounts of the compounds I would need in the solution. I think I should be able to do that, except I want to accurately determine that ratio of the acid and conjugate base, accounting for the effect of temperature on pka. But the only values for the pka I could find were the generally quoted values which I believe are at 20 Celsius. Is this known as the thermodynamic pka? How do I account for the effect of temperature on the pka into my calculations? Or is not required to do so? And what is the difference between thermodynamic ka and apparent ka anyways? Greatly appreciate any help!
bicarbonate buffer: H2CO3 <--> HCO3- + H+
Phosphate buffer: H2P04- <--> HPO42- + H+
Pka = ([H+][A-])/([HA])
I found a buffer calculator (http://www.biomol.net/en/tools/buffercalculator.htm) that allows you to input the temperature. When the recipe is produced, it also gives an apparent pka value. So is safe to simply use this apparent value in my calculations? Or are there any other considerations i must make such as ionic strength? But I don't fully understand what ionic strength is and how it affects the buffer.
I am afraid you won't be able to deal with calculations without understanding at least the very rudimentary concepts of the Debye-Huckel theory (at least at the level outlined here).
At the moment temperature is probably the least of your worries, as it is ionic strength of the solution changing the Ka value that is the main problem you will be facing initially.
As far as I can tell "apparent pKa" typically refers to the value adjusted for the ionic strength, changes with the temperature are much lower. Ka values listed in tables are valid only for infinitely diluted solutions.
You can try another buffer calculator, which does make corrections for both temperature and ionic strength. Note, that these theoretical values are almost always a bit off, theories we use are quite good for diluted solutions, but for concentrations higher that 0.1 M they start to fail. There are theories using experimental coefficients that work for higher concentrations, but typically you will find required correction coefficients were not determined yet.
Alright, thanks for the help.
Harder to advise when we don't completely know what do you are trying to do and achieve. For example is it trying to observe the specific effects of bicarbonate or phosphate on some system and to be sure effects are not just something secondary to do with ionic strength or osmolarity?
Would it be possible to while doing the best you can with these calculations, to smother the uncertainties by making the main ionic strength or osmolarities due to something else like NaCl or Na2SO4 ?
Since you think these things are significant then when you report your results you should state the actual composition of your solutions and any pH measurements you made (stating the conditions and any standardisations) in case anyone should want to repeat or interpret your experiments, otherwise anyone reading it will be no wiser than we are now.
12K
18K
13K
33K
12K
