Third order linear ODE Wolfram Math. problem
  • Level: Graduate
  • Thread starter Thread starter dperkovic
    Linear Ode
5 replies · 7K views
dperkovic
I have a problem with this homogenous ODE:
[tex] \frac{d^3x}{dt^3} + 2\frac{dx}{dt} = 0$[/tex]
With substitution [tex]x=e^\lambda t[/tex], I got characteristic polinom: [tex]\lambda^3+2\lambda=0[/tex].
So,
[tex]\lambda_1 = 0[/tex], [tex]\lambda_{1,2} = \pm\sqrt{2}i[/tex]
Because we have one real,and one pair of complex roots of characteristic polinom, general solution of ODE is:
[tex]x(t) =C1e^{0\cdot t} + C2\cos(\sqrt{2}t) +C3\sin(\sqrt{2}t)[/tex],
or:
[tex]x(t) =C1 + C2\cos(\sqrt{2}t) +C3\sin(\sqrt{2}t)[/tex]
But, Wolfram Mathematica's command DSolve[x'''[t] + 2*x'[t] == 0, x[t], t],give to me this:
[tex]x(t) =C1 - \frac{C2\cos(\sqrt{2}t)}{\sqrt{2}} +\frac{C3\sin(\sqrt{2}t)}{\sqrt{2}}[/tex].
As we can see, there is difference between my and wolfram's solution. Why ?? Where is a mistake in my procedure ?
Thank's. I thought that. But still, I can't figure out why constants in Mathematica's solution is different than constants i my solution. From which algorithm coming this "complicated" constants ?
The Mathematica DSolve usually looks for general solutions that match your particular equation and then it uses the form of the general solution to solve your specific problem. Often the general solution has such "complicated" constants.
In this case the general form is probably something like:
[tex]a x'''(t)+b x'(t)=0[/tex]
Which has the general solution:
[tex]\frac{\text{C1} \sqrt{a} \sin \left(\frac{\sqrt{b}<br /> t}{\sqrt{a}}\right)}{\sqrt{b}}-\frac{\text{C2} \sqrt{a} \cos<br /> \left(\frac{\sqrt{b} t}{\sqrt{a}}\right)}{\sqrt{b}}+\text{C3}[/tex]
Which turns into exactly the expression you have above for a=1 and b=2
This is the explanation which I looking for :smile: :smile: :smile:. Thank you !
