This is known as the Sector Area Formula.
  • Topic:
  • Thread starter susanto3311
    Area Circle
11 replies · 4K views · last reply
susanto3311
hello guys..
how to figure it out this below problem, find area of circle
please, see my picture..
thanks...
susanto3311
  • Circle diagram with radius labelled r = 21 cm, a central angle of 240 degrees marked inside the large sector, and a green arrow pointing to a region labelled Area = ?.
What are your thoughts here on what you should do?
i confused about 240...how to elaborate with commonly area formula?
If $240^{\circ}$ is outside the sector whose area we want, then what angle is inside, and then what portion of the whole is this?
Can we generalize from this to get a formula for the area of a circular sector?
can you make to me more simple, i think be illustrated with my problem sample.
A circle "encloses" $360^{\circ}$...if $240^{\circ}$ is outside the sector we want, how much is inside?
hi Mark..
360-240 = 120, then...how to elaborate?...
MarkFL said:
What portion of 360 is 120?
=120/360=0.333, so...
Actually, we have:
$$\frac{120}{360}=\frac{1}{3}$$
So, what portion of the area of the whole circle do you suppose the area of the sector would be?
MarkFL said:
Actually, we have:
hi Mark, finally
i think like this :
It's true, Mark?
  • Handwritten-style text showing 1/3 x πr² on the first line and 1/3 x 3,14x21² on the second line.
Yes, since 1/3 of the total angle within the circle is subtended by the sector, then its area is 1/3 of the whole circle. So, we could generalize and state that if the angle subtended within two radii of a circular sector is $\theta$ (given in radians) then the area $A$ of the sector is:
$$A=\frac{\theta}{2\pi}\cdot\pi r^2=\frac{1}{2}\theta r^2$$
