Time a spring takes to slow a mass
3 replies · 2K views
LANS
A mass M is attached to a spring with spring constant K. At the equilibrium point of the spring, the mass has a velocity of V.
M = 8.07 kg
K = 113 N/m
V_o = 0.638 m/s
How far does the mass travel until it stops? How long (in seconds) does it take for the mass to travel from the equilibrium point until it stops?
[tex]\frac{1}{2}MV_o^2 = \frac{1}{2}Kx^2[/tex] - equation 1
[tex]F(x) = kx[/tex] - spring force
[tex]V(x) = \sqrt{V_o^2 - \frac{Kx^2}{m}}[/tex] - from energy.
Using equation 1, I can solve part 1 easily. I plug in M,K,V to equation 1and solve for x, which gives me [tex]x = 0.1705m[/tex]
I have no idea how to solve part 2. I've tried using power, but that doesn't go anywhere meaningful.
[tex]P(x) = F(x)*V(x)[/tex]
Integrating for total power gives me
[tex]\frac{MV_o^2}{2t} = \int F(x)*V(x)[/tex]
Simplifying the integral:
[tex]\frac{MV_o^2}{2t} = \int \sqrt{K^2 x^2 V_o^2 - \frac{K^3 x^4}{m}}[/tex]
I've tried solving that for t, and it doesn't give me the right answer. I haven't thought of it yet, but I feel like there should be an easier solution to this problem. Any help is appreciated.
It might be easier to cast this as a SHO formulation where T can be found directly from the other variables. in other words can you convert this to the form
x(t)=A sin (wt) and solve for T. hint: w=sqrt(k/m) and the time to stop is 0.5T.
Have you learned the formula for the period of a mass-spring system? The time it takes to go from equilibrium to rest is actually 1/4T (not 0.5T).
my bad. I forgot it was a quarter cycle and not 1/2, thanks for the correction.
