Time as a function of distance for constant a
18 replies · 10K views · last reply
DaveC426913
2025 Award
I want to make a little calculator that will
- take a distance (such as, say, 20.7 light years) and,
- with a given acceleration (say, 1g) followed by deceleration,
spit out the time elapsed.
I don't know how to fold Lorentz' velocity function into the formula for t as a function of d and a.
The information should be extractable from http://math.ucr.edu/home/baez/physics/Relativity/SR/rocket.html
You'll be piecing together two trips, one for acceleration and the other for deceleration.
[tex]d=[\sqrt{1+a^2t^2}-1]/a].[/tex]
Solve for t.
Do you want the time elapsed by clocks on the ship, or in the frame where the ship was at rest at the beginning and end of the journey?
Yes! :biggrin:
(Both)
And nertz to me for neglecting to say so up front...
Solve for t.
As Jesse wisely asks, is that ship time? or Earth time?
Just look at the page robphy pointed you to, all the terms are defined, and the equations you need are there. They say:
The acceleration of the rocket must be measured at any given instant in a non-accelerating frame of reference traveling at the same instantaneous speed as the rocket (see relativity FAQ on accelerating clocks). This acceleration will be denoted by a. The proper time as measured by the crew of the rocket (i.e. how much they age) will be denoted by T, and the time as measured in the non-accelerating frame of reference in which they started (e.g. Earth) will be denoted by t. We assume that the stars are essentially at rest in this frame. The distance covered as measured in this frame of reference will be denoted by d and the final speed v. The time dilation or length contraction factor at any instant is the gamma factor γ.
So you want to find the equations on that page which give you t or T if you already know d and a. Those would be:
t = sqrt[(d/c)^2 + 2d/a]
and
T = (c/a) ch-1 [ad/c^2 + 1]
These equations are for continuous uniform acceleration, so if you want to accelerate for half the trip and then decelerate for the second half, that's equivalent to double the time it would take to accelerate uniformly for half the distance. So the equations would become:
t = 2 * sqrt[([d/2]/c)^2 + 2d/a]
and
T = 2 * (c/a) ch-1 [a(d/2)/c^2 + 1]
ch-1 is the inverse hyperbolic cosine function, acosh. Here is an online calculator which understands the function acosh(x), but if you want to program your own calculator, this page says that [tex]acosh(x) = log[x + \sqrt{x^2 - 1}][/tex].
OK, so I kind suck at advanced math, making me the world's worst physics geek.
So I made a connect-the-dots graph from the data they provided. See attached. Four whole data poiints... But it gets me a number within 10%.
So, a 20.7ly journey is actually two symmetrical 10.35ly journeys, and a 10.35ly journey at 1g shows 3.2 years elapsed shiptime.
Thus, the whole journey lasts 6.4 years shiptime, while by Earth-time the journey lasts just a little more than 21 years.
Cool.
  • Hand-drawn graph of Earth time against ship time for a constant-acceleration journey, with a red curve rising steeply and labelled points including 1, 1.19; 2, 3.75; and 5, 83.7.
On an loosely-related note, that page clears up some things I was never quite sure about in relativistiic travel.
It's a staple of sci stories that have long space journeys where they return to an Earth that's a zillion years older than when they left.
I'd never quite gotten the idea of whether something weird is happening to Earth-time, or ship-time or both. As if, by virtue of their trip, Earth-time had gone into overdrive and they had "missed" all those years.
But I'm beginning to see that even the ship's occupants can be sure that Earth's clock is "the right one" (forgive me Einstein).
A spaceship is scheduled for Star X, which everyone agrees is 83ly away. The spaceship occupants, once they get up to speed, see that their measurement of the distance to Star X is not fixed - it is not a journey of 83 light years, it is a journey of merely 5 years. Yet when they get to Star X, they see that Sol is once again 83ly away.
So, even *they* agree that the journey should - and did - take 83 years from a PoV stationary to both Sol and Star X.
So I can lay to rest my confusion. A journey of 100ly takes ~100 years - by Sol time AND by Star X time. The ship occupants acknowledge that it was they who slowed to a crawl while 83 years elapsed normally.
Or looking at it the other way, when the Niven's Rammer did his loop around the galactic core and came back "two million years in Earth's future", he really did make a trip (and one that he could plot and measure on a galactic map) whose duration should have been - and was - 2 million years.
In the equation I gave, t is the Earth time.
It's all in the proper quantities
Good thing!
The proper distance, which is the actual distance traveled by a traveler, is always smaller than the distance as measured by a reflecting light beam. So in other words, if the distance between two planets is X then any traveler must record a distance smaller than X.
Gives an interesting spin on Zeno's paradox doesn't it? :wink:
Proper acceleration changes proper distance, which is the reason that travelers traveling between two events can record a different proper time. :smile:
I got 6.1 years and 22.6 years...one thing to remember is that, as noted on the relativistic rocket page, if you're using units of years for time and light-years for distance, then 1G acceleration is 1.03 ly/y^2.
and
Wow thanks! That first one works perfectly.
The second one I'm trying to massage. This is what I get:
n = a*(d/2)/c^2 + 1
m = Math.log(n+Math.sqrt(n*n-1))
Te = 2 * (c/a) * m
Unfortunately, that spits out a number in the millions.
n = a*(d/2)/c^2 + 1
Te = 2 * (c/a) * m
Hmm, try having your program print out n and m as well as Te to give you a better idea of where it's going wrong. If I use your example of d = 20.7, then with a=1.03 and c = 1 I get:
n = 11.6605
m = 3.1475 (BTW, make sure you're using the natural log function 'ln' rather than log base 10)
Te = 6.11
Math.log(x) returns the natural log (base E) of x
What units is c in? I set it to 300000.
a = 1.03
d = 20
c = 300000;
n = a*(d/2)/c^2 + 1
ch1 = Math.log(n+Math.sqrt(n*n-1))
Te = 2 * (c/a) * ch1
alert(" Te:" + Te + " n:"+n +" ch1:"+ ch1 );
yields
Te:1026843.0140033511 n:3 1.7627417
You can use whatever units you want, you just have to be consistent. If you want 1G acceleration, the a = 1.03 figure assumes you're using units of years for time and light-years for distance, in which case c = 1. If you want to use c = 300000, that means you're using units of kilometers for distance and seconds for time, in which case 1G acceleration would mean a = 0.0098 kilometers/second^2.
DaveC426913 said:
a = 1.03
d = 20
c = 300000;
This would mean a distance of 20 kilometers and an acceleration of 1.03 km/s^2 = 105G, which is not what you wanted. But even with these numbers, something seems to be going wrong with your program's math:
DaveC426913 said:
]n = a*(d/2)/c^2 + 1
alert(" Te:" + Te + " n:"+n +" ch1:"+ ch1 );yields
If n = a*(d/2)/c^2 + 1, then you can just plug this into your calculator to see a*(d/2)/c^2 = 1.03*(10)/(300000)^2 = 1.144 * 10^-10, so n should be very close to 1. Have you checked the programming language's rules for entering equations? Maybe you need to have [d/2] instead of (d/2) of something minor like that. Anyway, I'd suggest entering different simple numbers (like a=1, d=1, c=1) to try to figure out what equation it's actually calculating, or break the equation up into more intermediate variables (like x = d/2, y = a*x, z = y/c^2) which it can print out so you can get a better idea of just where it's going wrong by double-checking the results with a calculator.
I wish to verify something:
This:
is actually
T = 2 * (c/a) * ch-1[a(d/2)/c^2 + 1]
Right?
Nope.I can't reconcile these two statements:
T = 2 * (c/a) h(a(d/2)/c^2 + 1)
where h(x) = log(x+x^2-1)
This:
is actually
Right?
That's right.
h(x) is supposed to be log(x + sqrt(x^2 - 1)). So just calculate the value of a(d/2)/c^2 + 1, and let that be x in the second equation. For example, if d = 20.7, a=1.03 and c = 1, then a(d/2)/c^2 + 1 = 1.03*10.35 + 1 = 10.6605 + 1 = 11.6605, so according to this calculator acosh(11.6605) = 3.14751047236, and log(11.6605 + sqrt(11.6605^2 - 1)) = log(11.6605 + 11.6175) = log(23.278) = 3.1475.
