Time Dilation: Hafele-Keating Experiments
The discussion revolves around the principles of time dilation as illustrated by the Hafele-Keating experiments, particularly in relation to the concept of light clocks. Participants explore whether the mechanisms of cesium beam atomic clocks used in the experiments are analogous to those of light clocks, which serve as a theoretical model for understanding time dilation.
  • Some participants express understanding of time dilation through the light clock thought experiment and question if the Hafele-Keating experiments operate on the same principles.
  • One participant notes that while light clocks are theoretical teaching tools, they assume that if a light clock slows down in a reference frame, then all comoving clocks must also slow down.
  • Another participant clarifies that cesium clocks are not light clocks but have been compared to them in various reference frames, suggesting they are equivalent in terms of time dilation effects.
  • There is a discussion about whether the cesium clock operates on a similar metronomic principle as the light clock, with some participants indicating they are not the same but can be analyzed using similar relativistic principles.
Participants do not reach a consensus on whether the mechanisms of light clocks and cesium clocks are the same, with some asserting they are not the same while others suggest they can be analyzed similarly under the principles of relativity.
There are unresolved questions regarding the specific operational principles of cesium clocks compared to light clocks, and the discussion reflects varying levels of understanding and terminology among participants.
This discussion may be useful for those interested in the concepts of time dilation, relativity, and the mechanics of atomic clocks in comparison to theoretical models like light clocks.
Maaruk
Hi, I went ahead and read through all the similar discussions and none are on this particular topic so I'll go ahead and shoot. I did find this topic as well, but my question is pretty simple.
I think I understand how time dilation works, I read through the explanation here, this jives with the explanation provided in this World Science Festival panel in this video (it starts at around 11:30 if the link didn't work). This is the light clock thought experiment where it shows why a light particle in the moving clock is bouncing slower than the one in the stationary clock. This makes sense to me, and I wondered if the Hafele-Keating experiments which use a cesium beam atomic clocks work on the same basic principle described?
Maaruk said:
... I wondered if the Hafele-Keating experiments which use a cesium beam atomic clocks work on the same basic principle described?
Why would they behave any differently?
Hi Maaruk, welcome to PF, and thank you for taking the time to dig around a bit and come with a thoughtful question!
So the hypothetical clock which is a pulse of light bouncing back and forth is called a light clock. It is primarily meant to be an easy to analyze teaching tool. As far as I know there is not any such clock built that actually works that way. However, assuming that the principle of relativity is true then if a light clock slows down in a reference frame then so must all other comoving clocks.
Edit: I just had a thought that you could consider the microwave cavity to be a kind of mirror arrangement
From the description of the atomic clock used in the H-K experiment it wasn't clear to me whether the cesium clock uses the same metronomic principle as the light clock.
Thank you for the welcome.
I definitely appreciated how easy the light clock concept was to understand, and why movement would affect its measurement of time. I just wasn't clear on whether the atomic clock in the H-K experiment operates with roughly the same principle and something very similar to the light clock thought experiment is happening in the H-K experiment. Maybe more clearly, are the mechanisms of the light clock and the cesium clock roughly the same? I think I see what you are saying about the microwave cavity, I read through 5 different descriptions of the cesium clock and I still wasn't sure so I thought I would find someplace to ask :biggrin:
Cesium clocks are not light clocks, but they have been compared to light clocks in various reference frames: They are equivalent.
Thanks guys, very helpful. Asking accurate questions is very helpful, and I know sometimes I do not ask accurate questions. Plus it doesn't help that I am usually a mess of terminology but I generally know what I mean by something. Thanks again.
Your first thread here is exemplary -- Welcome to the PF. :smile:
As mfb says, they are definitely not the same. For the light clock, the point is that you can use the second postulate to analyze how the clock rate changes with speed and then you use the first postulate to extend that analysis to atomic clocks (or any other kind)
  • · Replies 46 ·
  • · Replies 54 ·
  • · Replies 58 ·
  • · Replies 16 ·
  • · Replies 58 ·
