Understanding Time Dilation: Explained with an Everyday Example | Help Needed"
The discussion centers on the concept of time dilation, specifically the phenomenon where moving clocks run slow relative to stationary observers. A scenario is presented involving a spacecraft traveling at high speeds, illustrating that while a stationary clock shows 5 PM after one hour, the clock on the spacecraft will show an earlier time due to the effects of time dilation. The equation used to calculate time distortion is Einstein's t' = (1-velocity/speed of light)^-(1/2). The discussion emphasizes that observers on the spacecraft perceive distances differently due to length contraction, leading to discrepancies in time readings between moving and stationary clocks.
  • Understanding of Einstein's theory of relativity
  • Familiarity with the concept of light speed as a constant
  • Basic knowledge of time dilation and length contraction
  • Ability to apply mathematical equations in physics
  • Study Einstein's theory of relativity in detail
  • Learn about the implications of light speed constancy in physics
  • Explore practical examples of time dilation in high-speed travel
  • Investigate the mathematical derivations of time dilation and length contraction
Students of physics, educators teaching relativity concepts, and anyone interested in the implications of high-speed travel on time perception.
logearav
Time Dilation --- Help needed
Time dilation says, " Moving clocks run slow".
For example, a stationary clock shows 4 PM and at the same 4 PM a spacecraft moves with a clock inside it showing the same 4 PM. Now after an hour, the spacecraft returns to earth. The stationary clock will show 5 PM. I presume the clock in the spacecraft will also show 5 PM. Then how can we say moving clocks run slow. Forgive if i sound silly. I need clarity on this concept. Thanks in advance
The idea of time dilation is that light moves at the same constant rate seen from any perspective and that other moving objects don't. As you move faster you're perception of reality has a decreased rate. Everything else appears slower to you. To find the time distortion you would use Einstein's equation:
Whichever clock is moving faster is going to be the clock that reads the earlier time.
You are assuming that the observers on the spaceship will say that they spent 1 hour traveling. But this does not happen; the spaceship observers will see the distance between the Earth and themselves to be contracted, which is another affect of traveling at high speeds (length contraction). So when the spaceship observers see themselves reaching the Earth by traveling a different distance than the Earth observers say, they will show a different time than the Earth observers (depending on the speed they travel at).
Thanks everyone for your replies
  • · Replies 16 ·
