Time Dilation & Relativity: Going Back
This discussion centers on the complexities of time dilation and relativity, particularly during a spacecraft's journey away from and back to an observer. The conversation highlights that while the outward journey may appear to take 1.1 years from the observer's perspective, the return journey does not simply mirror this; it involves the Doppler effect, which influences perceived time. Key concepts include the distinction between coordinate time, proper time, and the impact of light travel time on observations. Ultimately, the discussion emphasizes that the path taken through space-time results in different elapsed times for the traveler and the observer.
  • Understanding of Einstein's Theory of Relativity
  • Familiarity with the Doppler Effect in physics
  • Knowledge of time dilation concepts
  • Basic grasp of space-time diagrams
  • Explore the mathematical framework of time dilation in special relativity
  • Study the implications of the Doppler effect on light and sound
  • Investigate space-time diagrams and their applications in relativity
  • Watch educational videos on time dilation and relativity for visual understanding
Physicists, students of relativity, and anyone interested in the nuances of time perception in high-speed travel scenarios.
faramund
I've read many explanations of time dilation and relativity, that describe things from the point of an observer, and then some other object moves away from it at some fraction of light speed. i.e. say a spacecraft moves away from an observer at 0.1c for 1 year ship time. Then presumably, to an observer, it really appears to take 1.1 years, and presumably appears to have a speed of 0.1/1.1 (I know some of this maths, is possibly slightly off - I'm trying to state this in general).
But, then I always wonder, what happens when it comes back. I'm really unsure of how to describe the maths of this, but wouldn't it look faster coming back, somewhat like the doppler effect. It seems symmetric, if total ship time for ship occupant's is 2 years, and it seemed like it took 1.1 to go out, it seems like it would - from the observers point of view - that it would take 0.9 to come back.
What am I missing?
faramund said:
What am I missing?
Yes on the way back you would see the doppler effect just as on the way out (blue-shift to the front(ish), red shift behind). On the other hand, the return journey itself is just the outward journey in reverse, so all times (and distances) are the same!
You also need to be more specific about what you mean by "time", because there is more than one "time" involved. This video shows a two-way journey (accelerated/decelerated, not constant speed). Gaze at the pretty pictures if you must, but then concentrate on the clock display at the top left (view in HD to see properly). The red clock is the coordinate or "scene" time on the nearest clock to you (all the red dots are actually synchronized across the whole scene, but you don't see that because of light travel time delay). The yellow dot is a clock on the place that you leave and return to (as if seen through a telescope, including the doppler shift). The green clock is your "proper" or wristwatch time. At the end of the journey, the red and yellow clocks are identical, but your wristwatch time is lagging them because you went somewhere and came back to your starting point.
While it is true that the statement "...because you went somewhere and came back to your starting point" is correct, it really is not in any way explanatory. Much better is to say " ... because you took a path through space-time that used less time". That is, the statement as you made it seems to imply that only space is involved whereas the actual reason is because space-time is involved.
There's quite a lot of sloppy terminology used about this. What you see is exactly what you say - clocks of someone moving away from you tick slowly and clocks of someone moving towards you tick quickly. This is the Doppler effect.
However, if you subtract out the light travel time you will calculate that the clocks are ticking slowly in both directions. This is time dilation - what's left over after you correct for the light speed delay.
You do get people referring to this calculated result as "what you see", but that's not really right. That's what you work out is happening based on what you see.
  • · Replies 26 ·
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 58 ·
