How do I find the time evolution of a state with an operator in the Hamiltonian?
The discussion focuses on finding the time evolution of a quantum state \(\Phi(x) = \exp(-x^2)\) under the Hamiltonian \(H = \frac{p^2}{2m} + \frac{x^2}{2}\). Participants confirm that the time-dependent state can be expressed as \(\Psi(x, t) = \exp(-iHt/\hbar)\Phi(x)\), but emphasize the need for normalization and the use of eigenstates. The Fourier transformation method is suggested for deriving the time-dependent state, with the energy \(E\) expressed as \(E = (n + \frac{1}{2})\hbar\omega\) for the harmonic oscillator. The discussion also touches on coupled harmonic oscillators and the application of ladder operators for solving the Schrödinger equation.
  • Understanding of quantum mechanics concepts, particularly Hamiltonians and wave functions.
  • Familiarity with Fourier transformation techniques in quantum mechanics.
  • Knowledge of quantum harmonic oscillators and their energy levels.
  • Experience with ladder operators and their application in solving quantum systems.
  • Study the derivation of the time evolution operator in quantum mechanics.
  • Learn about the application of ladder operators in quantum harmonic oscillators.
  • Explore the properties and applications of Fourier transformations in quantum mechanics.
  • Investigate the behavior of coupled harmonic oscillators and their solutions.
Quantum physicists, students of quantum mechanics, and researchers interested in the time evolution of quantum states and harmonic oscillators.
KFC
Suppose I know an initial state \Phi(x)= \exp(-x^2), the Hamiltonian is
H = p^2/2m + x^2/2
where p is the mometum operator. If I want to find the time evolution of the state \Phi(x), should I write it as the following?
\Psi(x, t) = \exp(-i H t/\hbar)\Phi(x)
However, since H contains an operator, I don't know how to find the close form of the time-dependent state. Should I expand it as a series and then operate it on \Phi(x) term by term? But in this way, it seems not easy to combine the result to get the close form!?
The H in the exponential should be E - as in the energy of that eigenstate. I think what you have there is an Eigenstate (it's been a while since I did Quantum harmonic oscillators, and the forms I solved for were somewhat different so I'm not sure), if it isn't then you can't do this. You need to normalize the wave function, in any case.
Thank you. I read a text in which the author use the Fourier transformation to carry out the time-dependent state.
\Phi(k) = \frac{1}{\sqrt{2\pi}}\int dx \exp(-ikx) \Phi(x)
and then the time-dependent state is the inverse transformation of \exp(-iEt/\hbar)\Phi(k)
\Psi(x, t) = \frac{1}{\sqrt{2\pi}}\int dk \exp(ikx)\Phi(k) \exp(-iEt/\hbar)
For harmonic oscillator, if H = p^2/2m, then E=\hbar^2k^2/2m, plug this into the inverse Fourier transformation will give the result directly. But if H also includes x^2/2, what does E (in terms of k) look like?
By the way, if we consider two coupling hamonic oscillator such that
H = p_1^2/2m + x_1^2/2 + p_2^2/2m + x_2^2/2 and we apply the Fourier transformation again to find the time-dependent state, how to write the Fourier transformation? Should it be 2D Fourier transformation?
Uhm...I don't think you need to worry about Fourier transforms for this problem (all you did was transform the function over to wave number space and then transform it back... tagging on the exponential term does nothing with that integral since it's over dk). The problem can be solved directly from the Schroedinger's equation using ladder operators or using Legendre polynomials.
The energies of the quantum harmonic oscillator is:
E=(n+\frac{1}{2})\hbar\omega
I believe the wave function you provided corresponds to n=1 state...but there are some missing coefficients in front of the x squared term...so I'm not sure if it indeed is... You may want to check that.
Where \omega = \sqrt{\frac{k}{m}}
k is the spring constant as usual, and in your case it is 1.
You can obtain this by using ladder operators. This problem has been completely solved so I don't think I need to redo everything here. You can find information about this problem in the wiki: http://en.wikipedia.org/wiki/Quantum_harmonic_oscillator
I don't understand your coupled oscillator, why is there a p_2 and x_2 term? Are there 2 particles in there?
Yes. There are two particles.
Hmmm, sorry but I can't help you there. I haven't studied two particle systems yet.
