Timelike v. spacelike, is it arbitrary?
  • Level: Graduate
  • Thread starter BruceW
177 replies · 20K views · last reply
WannabeNewton said:
Neighborhoods encode all the information about limits in topological spaces. Keep in mind that an arbitrary space-time manifold has no natural metric so ##\epsilon##-##\delta## definitions of limits don't apply. In topological spaces, neighborhoods fully characterize limits...
ah great, I'm glad there is meaning behind it. and thanks for the names of texts.
PeterDonis said:
First, a clarification: strictly speaking, the terms timelike, spacelike, and null apply to *vectors*, not curves--more precisely, they apply to tangent vectors to curves at particular points.
Could you also please provide a definition of "spacetime interval" as applied to Special Relativity?
Thanks.
WannabeNewton said:
Indeed worldline refers only to time-like curves in space-time.
As I said in post #133, Taylor and Wheeler also include lightlike paths.
Who's right? Where do we go to get the commonly accepted definitions for words like "worldline"?
The restriction of "worldline" to timelike curves is not universal. From a google text search, Synge, Sachs&Wu, Schutz, and Ludvigsen also apply worldline (or "world-line" or "world line") to light. There are certainly others.
So, such a term is likely defined locally within the text or article. If precision is needed, one should use a more descriptive phrase like "timelike curve", which also should be defined or refined if needed.
But:
For the lightlike case, the "curve" is null having a "length of zero" and therefore I would think the expression "tangent vectors to curves at particular points" would have no meaning. Is this the reason some authorities exclude "lightlike" from the definition of "worlineline", simply because there is no line there?
Also, do all authorities agree that "worldline" cannot apply to a spacelike curve? For example, is definition.com at least correct that "the path of a particle in space-time" excludes spacelike curves? If so, is there a more technical term than "path" or "curve" that includes all three of the different categories (timelike, lightlike or null, and spacelike) so that we can talk about the interval between two events without knowing or specifying which one it might be?
(I think) you can still find the tangent vector at points along a null curve. It is just that when you integrate, you get zero. And that's a good question about a general term for timelike, null and spacelike curves. I've seen simply the word 'curves' used. But I'm not sure if this is standard.
No, a null curve can still have a perfectly well-defined tangent vector at each of its points, it's just that that vector will have zero length according to the metric. Tangent spaces and vectors within them exist independently of the metric that assigns a zero length to certain vectors.
I've never seen any other general term besides "curve" that includes all three categories. (The term "geodesic" can be applied to a curve in any of the three categories, but of course not all curves are geodesics.)
Since Euclidean/Riemannian geometry has a positive-definite metric,
there is essentially only one kind of vector.
However, for pseudoRiemannian geometry, there are more than one type:
for Lorentzian-type.. three kinds (timelike, spacelike, null) ;
for Galilean-type, two kinds (spacelike and null coincide).
In the pseudo-Riemmannian cases, I would use "curve" to be the most general... including zigzaggy ones (Penrose's "bad trip") or ones that may change the type of tangent-vector, which is mathematically allowed. To less-ambiguously refer to specific subsets of curves, one should use additional terms, e.g. [smooth] future-timelike curve. (Some references [like Penrose's "Techniques of Differential Topology in Relativity"] distinguish between paths (a mapping) and curves (the image of a mapping).)
A curve is simply a map from an interval in the reals into the smooth manifold such that the map itself is smooth. The qualifiers timelike, nulllike, or spacelike for curves just means that the tangent vector field to the curve is of that character.
BruceW said:
ghwellsjr said:
However, there is a commonly accepted standard definition for spacetime interval in SR and it excludes curved paths. It is always the longest ... path between any two arbitrary events.
Where do you get that definition of spacetime interval from? I'm pretty sure that is not the standard definition. For example, in the twin paradox, we talk about the spacetime interval along the path taken by the accelerating twin. (and since the twin is accelerating, this is not the longest worldline between events).
Every book I have seen, every article I have seen, every definition I have seen states that the spacetime interval between two events is invariant so we never talk about it with reference to the path taken by the accelerating twin.
Can you point to one reference that says that the spacetime interval applies equally to both twins?
It is the same thing. If you can measure the distance between two close points (ds) then you can integrate those distances to get the total distance along a path (s).
Things get more complicated in curved spaces. In flat spaces there is one unique path which is the extremal distance, and so you can say that the length of that path (s) is the distance between the points. However, in curved spaces there may be multiple extremal paths, so it is difficult to call the length of one the distance.
For a reference I would read Carroll's lecture notes on GR, but it isn't a single part of the notes but rather a synthesis of the first few chapters.
I was specifically talking only about Special Relativity. And the question is can the Spacetime Interval apply to both the accelerating twin and the inertial twin?
Yes. If you can measure the "straight" interval between two close points (ds) then you can integrate those intervals along a curved path to get the total interval along the path (s).
I think there is a tendency to use spacetime interval both for something that is a function of two events (in which case you are implicitly discussing either SR or a sufficiently small region of spacetime in GR, such that the geodesic is unique), or as a function of a path in spacetime. It would be nice if there were clearer terminology, but generally the context is used to disambiguate (are we talking only about points/events, or are one or more paths being considered).
I think of the spacetime interval [between two nearby events] as [the square of] an infinitesimal bit of arc-length (the line element), dependent on the event and an infinitesimally-close nearby event.
For the case of a timelike curve, the integrated arc-length [along that path] is the proper-time (measured by a clock that traveled along that curve).
These notions are distinct.
Because of the symmetry properties of SR,
along a geodesic ("straight line") in SR,
the two notions can be loosely identified.
I would not, however, loosely identify the spacetime-interval between two events with
the proper-time along the traveling twin's non-geodesic worldline between those events.
[edit...]
p.s.
The spacetime-interval between two events is more closely related to an infinitesimal "displacement",
whereas the integrated proper-time along an arbitrary path between is closely related to the "total distance traveled".
[edit...]
p.s.
But, especially in SR, one speaks of an interval between points with finite separation, where the interval can be of any character. Even in GR, this is possible within a 4-volume such that the geodesic is unique. (This is the basis if Synge's world function of pairs of events with finite (but not too large) separation, with the interval being of any character). With interval specified between points with finite separation, you must implicitly assume a unique geodesic between them.
Similarly, integrated interval can be applied to any path all of whose tangents are of the the same character (or, with trickery I find devoid of meaning, to any path at all). The integrated interval along a path will be a proper time if all tangents are causal, and a proper length if all are a-causal. The proper time has a much more direct physical meaning, but the length can also be given a physical meaning:
- each nearby pair of points is such that there is local observer for whom they are at rest [edit: simultaneous is really what is important], and who can measure a ruler distance between them. Add these up over the curve, and you get its proper length (also taking the limit to zero of affine parameter between successive points).
The restriction to sufficiently small open sets is indeed very essential with regards to uniqueness and maximality of length for time-like geodesics. It is not true that between any two points there is a unique time-like geodesic that maximizes the proper time. For example, one can take Minkowski space-time and roll it up into a cylinder; one can find two points between which there are two time-like geodesics (one that goes straight up the cylinder and another which coils around it) and it is the latter which maximizes the proper time.
Don't you mean the former? The one that goes "straight up the cylinder" (i.e., the one with a winding number of zero) is the one that globally maximizes the proper time. (I say "globally" because each geodesic maximizes the proper time locally--in this case, within the class of all curves with the same winding number.)
that is awesome. Is that because 'flat' and 'cylinder' are homeomorphic? Or is it diffeomorphic? (I don't know much about isomorphisms, but I think they are pretty interesting).
Well let's take the unit square in 1+1 Minkowski space-time. To roll up the unit square into a cylinder, we simply curl every horizontal strip of the square into a circle i.e. we identify the endpoints of each strip. So on the plane, if we wanted to connect say ##p = (0,\frac{1}{4})## to ##q = (0,\frac{1}{2})## using a line, there is only one such line and it is simply the line ##l_1## drawn straight up from ##p## to ##q##. We can also draw a line ##l_2## from ##p' = (1,\frac{1}{4})## to ##q##; note that both lines are time-like curves. On the plane these lines of course start at different points but on the cylinder these points are identified so the two lines get mapped onto curves that have the same starting and ending points on the cylinder. The cylinder and plane are locally isometric so the geodesics of the plane (the lines) get mapped onto geodesics of the cylinder and arc-length will be preserved, meaning that the images of ##l_1,l_2## will be geodesics on the cylinder and that the image of ##l_1## will have greater length than the image of ##l_2## on the cylinder.
ah right, we want local isometry, since we want the 'same' metric on both. And (I think) we also need local diffeomorphism to get local isometry. And the reason we can only get a local diffeomorphism, but not a diffeomorphism is because of the 'edges' of the manifold?
Local isometry implies local diffeomorphism. We can't have a global diffeomorphism or even a global homeomorphism because the cylinder doesn't have a trivial fundamental group like the plane does i.e. the plane is simply connected but the cylinder is not (the fundamental group of the finite cylinder is infinite cyclic), and being simply connected is a topological invariant.
wikipedia seems to imply differently. http://en.wikipedia.org/wiki/Isometry_(Riemannian_geometry)
But on the other hand, they say here http://en.wikipedia.org/wiki/Diffeomorphism that "It is easy to find a homeomorphism that is not a diffeomorphism, but it is more difficult to find a pair of homeomorphic manifolds that are not diffeomorphic. In dimensions 1, 2, 3, any pair of homeomorphic smooth manifolds are diffeomorphic. In dimension 4 or greater, examples of homeomorphic but not diffeomorphic pairs have been found. The first such example was constructed by John Milnor in dimension 7." So I guess this means if we have a local isometry then we are likely to have local diffeomorphism, but is not certain?
ah, that makes sense. cool.
A local isometry is by definition a local diffeomorphism such that the metric tensor is preserved under pullback. So a map being a local isometry immediately implies it is a local diffeomorphism by definition.
ah ok, I need to read more about this kind of stuff. I've just found some university websites that are pretty good. (wikipedia's explanation was pointing me in the wrong direction, by the way it was worded).
thanks dude! that does look good. I'll definitely have a read if it is in my uni library - one of the perks of being at a university ;)
