Solving Hydrate Formula w/ Titration: Na2CO3.xH20
  • Thread starter Thread starter Zoey Brown
    Titration
The discussion focuses on determining the formula of a hydrate of sodium carbonate (Na2CO3.xH2O) through titration with hydrochloric acid (HCl). A sample weighing 2.316g neutralizes 38.49 mL of 0.4198 mol/L HCl, allowing for the calculation of moles of Na2CO3 present. The calculated moles of Na2CO3 are 0.00807906, leading to the need for further calculations to determine the mass of the hydrate and the value of x in the formula.
  • Understanding of titration techniques and calculations
  • Knowledge of mole concept and molarity
  • Familiarity with chemical formulas and stoichiometry
  • Ability to perform mass and molar mass calculations
  • Calculate the mass of 0.008079 moles of sodium carbonate (Na2CO3)
  • Determine the total mass of the hydrate by subtracting the mass of Na2CO3 from 2.316g
  • Calculate the number of moles of water (H2O) in the hydrate
  • Research the properties of hydrates and their formulas
Chemistry students, educators, and anyone involved in laboratory titration experiments or studying the properties of hydrates will benefit from this discussion.
Zoey Brown
The formula of a hydrate may be determined by titarion. If 2.316g of a hydrate of sodium carbonate is required to completely neutralize 38.49 mL of 0.4198 mol/L HCl,find the formula of the hydrate. The products will be NaCl, H20, and CO3
n=cv
m=mM
Na2CO3 . xH20 --> Solving for x
find moles of HCL
Use mole ratios
You are titrating (measuring) the amount of sodium carbonate in the sample. The rest would be water (the water of hydration).
so does the 2.316g not include the xh2o?
It does. But the titration result tells you how many moles of Na2CO3 are present, regardless of how much hydration water it contains.
so if I've found that there are 0.00807906 mol of Na2CO3, where would i go from there to find the formula of the hydrate?
What is the mass of the 0.008079 moles of the sodium carbonate?
would it be 2.316 g
Na2CO3 + 2HCl -----------> 2NaCl + H2O
Formula weight for sodium carbonate is 105.999 grams per mole
Formula weight for hydrogen chloride is --- will not be needed
Zoey Brown said:
would it be 2.316 g
Don't guess - calculate.
12K
9K
