Topology of R: Basis and Rationals
  • Thread starter Thread starter Damascus Road
    Basis Topology
The discussion focuses on the collection of sets C = {[a,b) | a PREREQUISITES
  • Understanding of basic topology concepts, including basis and open sets.
  • Familiarity with rational numbers and their properties.
  • Knowledge of the standard topology on R, specifically the definition of open intervals.
  • Ability to perform set operations, particularly intersections and unions.
  • Study the definition and properties of topological bases in more depth.
  • Explore the differences between various topologies on R, including standard and lower limit topologies.
  • Learn about the implications of using rational numbers in topology, particularly in generating bases.
  • Investigate examples of topological spaces that are not generated by standard open sets.
Mathematicians, students of topology, and anyone interested in understanding the foundational aspects of topological spaces and their properties, particularly in relation to rational numbers and basis sets.
Damascus Road
Consider the collection of sets C = {[a,b), | a<b, and and b are rational }
a.) Show that C is a basis for a topology on R.
b.) prove that the topology generated by C is not the standard topology on R.So, I know for C to be a basis, there must be some x \in R,
and in the union of some C1 \bigcap C2 there must be a C3, so that x \in C3.
So, since my C = {[a,b), | a<b,
Letting a1 < a2 < x < b1 < b2
my C3 = [a2, b1) \in C.
I'm confused how to work in the rational numbers however, must I truncate them or something? Don't know how this would fit into the logic..
thanks in advance.
You've got the right idea here. However, you're going to need to make the proof a bit clearer: What are you using for C_1 and C_2? Why did you choose C_3 to be [a_2,b_1)?
I'm not sure what you mean by this.
How about this:
Let C1 = [a_{1},b_{1}) and C2 = [a_{2}, b_{2}), then C1 \bigcap C2 gives C3.
Where C3 = [a_{2},b_{1}) ?
With regards to the truncation, I'm not sure how to prove that the topology generated by C is not in the standard topology when a and b are rational. Hence, I was thinking along the lines of some kind of truncation (to make it an integer)
Almost. Remember what you need to prove:
Given any two basis sets C_1 and C_2 and any point x\in C_1\cap C_2, there exists a basis set C_3 such that
x\in C_3\subseteq C_1\cap C_2.​
You're making this too difficult! Here's a hint: By definition, every basis set of a topology is open in that topology.
Ah, I think I see what I'm missing.
Let C1 = [a1,b1) and C2 = [a2,b2). Then there exists an x\in C_3\subseteq C_1\cap C_2. Where C3 = [a2,b1).
Although this doesn't sound like I'm proving anything, but rather just saying there is an x... so maybe this is still wrong.
Sorry, I'm still confused how to go about this, and partially what it's asking. The standard topology on R is just the real line, right? I can go on with just that?
Almost. What you need to do is show that no matter what point x you choose from the intersection C_1\cap C_2, you can find a basis set C_3 such that x\in C_3\subseteq C_1\cap C_2.
The standard topology on the real line is the topology generated by the open intervals (a,b); i.e., a set U is open in the standard topology iff it's a union of arbitrarily many open intervals.
Am I ok up until where I am? i.e. i need to add more?
My gut feeling is that it has something to do with the openness of the intersection... but I haven't found it in my notes yet.
So I need to show that it cannot be expressed as an arbitrary union of open intervals.
To show that a basis B generates a certain topology T, for any U in T, and for any x in U, you need to prove existence of a basis element from B which contains x and is contained in U.
This is a useful operative criterion which may help you.
I have an example in my book: "on the real line R, let B = {(a,b) \subset R | a < b} set of open intervals in R. Certainly every point of R is contained in an open interval and therefore is contained in a set in B."
Can I say something similar? Except my set isn't an open set of something, since that's not the same as saying it's open on R right?
Your sets are open sets in the topology generated by these sets, as a start. Now, you need to see what's the relation between this topology and the standard topology on R.
Take an open interval <a, b> in R. Take an element x in <a, b>. Does there exist an element from your collection which contains x and is contained in <a, b>?
Yes of course there is, since <a,b> is open. But I have [a,b)...
Well, precisely speaking, <a, b> being open doesn't prove the fact.
Let x be in <a, b>. Is there a rational number between x and a? Between x and b? What do you conclude?
That there's a rational number in every interval?
Do I need to do an analysis of each case of intersection to show c is a basis for a topology on R?
Yes, you should.
To check that some collection is a basis for a topology on a set, you need the two conditions mentioned in your posts above.
To check that some collection is a basis for a specific topology on a set, you use the condition I mentioned in posts #8 and #10.
  • · Replies 17 ·
