Solving Tough Differential Equations with Variation of Parameters | [SOLVED]
  • Thread starter Thread starter hils0005
    Diff eq
The discussion focuses on solving the differential equation y^(4) - 8y^(2) - 9y = 7e^(-3x) using the method of variation of parameters. The complementary solution Y(c) is derived as y = Ce^(3x) + Ce^(-3x) + Ce^(x)cos(x) + Ce^(x)sin(x), with roots identified as r = ±3 and r = ±i. The particular solution Y(p) is determined to be Y(p) = Axe^(-3x), leading to the final solution y = C(1)e^(3x) + C(2)e^(-3x) + C(3)cos(x) + C(4)sin(x) - (7/60)xe^(-3x). The discussion emphasizes the importance of correctly identifying roots and coefficients in the solution process.
  • Understanding of differential equations, specifically fourth-order linear equations.
  • Familiarity with the method of variation of parameters.
  • Knowledge of complex numbers and their role in solving characteristic equations.
  • Ability to perform differentiation and substitution in calculus.
  • Study the method of variation of parameters in greater detail.
  • Learn how to derive complementary and particular solutions for higher-order differential equations.
  • Explore the implications of complex roots in differential equations.
  • Practice solving similar differential equations to reinforce understanding of the concepts discussed.
Students studying differential equations, mathematics educators, and anyone seeking to enhance their problem-solving skills in advanced calculus.
hils0005
[SOLVED] Tough Diff EQ problem
y^(4)-8y^(2)-9y=7e^(-3x)
y^(4)=fourth derivative, y^(2)=second deriv.
Need to find complimentary solution and particular solution using variation of parameters
r^4-8r^2-9=0
(r^2-9)(r^2+1)=0, r=9,-1
Y(c)=Ce^(9x)+Ce^(-x)
I think the comp soln is right, but I am unsure on how to start on Y(p)
Are you sure about your homogenous solution? I suggest that you re-check your solutions of the indicial equation.
e^(-3x) right?
I tried taking the 4th deriv and 2nd deriv and plugging in which would equal
81e^-3x - 8(9e^-3x) - 9e^(-3x)=7e^(-3x)
but the left side = 0??
In reference to the PM, perhaps it would help if I draw your attention to the following lines
hils0005 said:
r^4-8r^2-9=0
(r^2-9)(r^2+1)=0
Good :approve:
hils0005 said:
r=9,-1
Not so, good. Notice the powers of r.
I'm quoting from the PM you sent me. As I said via PM, please note that in order to keep our assistance as transparent as possible, it is the policy of Homework Helpers not to provide tuition via PM.
hils0005 said:
sorry hoot,
its been along time since I have had to factor higher polynomials, I think this is correct:
Y(c)=(r-3)(r^3+3r^2+r+3)
(r-3)(r+3)(r^2+1), r=3, -3, 1+i
y(c)=Ce^(3x)+Ce^(-3x)+e^(x)cosx+e^(x)sinx
Then for Y(p) I would use Axe^(-3x) correct?
Now, in reference to your question,
Better :approve:. However,
You need to be careful with your constant coefficients here. The coefficients of the two exponentials need not be equal. Furthermore, you are missing the coefficients of the trigonometric terms.
Yes, since e-3x has already been found to be a solution, you cannot use e-3x as your particular solution. Axe-3x would be the usual alternative.
dumb mistakes!
r=+/- 3, and 1+i
Y(c)=Ce^3x + Ce^-3x + Ce^(x)cosx + Ce^(x)sin(x)
Y(p) =Axe^-3x
y'(p) =Ae^-3x - 3Axe^-3x
y''(p) =-3Ae^-3x - 3Ae^-3x + 9Axe^-3x
y'''(p) =9Ae^-3x + 9Ae^-3x + 9Ae^-3x - 27Axe^-3x
y''''(p)=-27Ae^-3x -27Ae^-3x - 27Ae^-3x - 27Ae^-3x + 81Axe^-3x=
81AXe^-3x - 108Ae^-3x
substitute:
(81Axe^-3x - 108Ae^-3x)-8(9Axe^-3x - 6Ae^-3x) - 9(Axe^-3x)=7e^-3x
-60Ae^-3x=7e^-3x
-60A=7, A=-7/60
Answer:
y=C(1)e^3x + C(2)e^-3x + C(3)e^(x)cos(x) + C(4)e^(x)sinx - 7/60xe^-3x
does this look correct,
hils0005 said:
dumb mistakes!
r=+/- 3, and 1+i
Back up! Your original equation was r^4- 8r^2- 9= (r^2- 9)(r^2+ 1)= 0
so r^2= 9 and r^2= -1. The roots of the first of those are \pm 3 but the roots of the second are not 1\pm i!
the sqrt of -1= 1i correct-----ohhhhh wow that changes things:
e^(0)cos(x)+e^0sinx= C(3)cosx + C(4)sinx(x)
y=c(1)e^3x + c(2)e^-3x + c(3)cosx + c(4)sinx -7/60xe^-3x ??
:redface::shy::blushing:
That's really really really embarrassing.
