Trace and Determinant Relationship: Proving the Relation with O(x^2)
  • Level: Graduate
  • Thread starter Thread starter alle.fabbri
    Determinant Trace
3 replies · 5K views
alle.fabbri
Hi,
can anyone give me an hint to proof the relation
det(I + x A) = 1 + x tr A + O(x^2)
thank you.
Write out the general form of (I+xA). The determinant must be some polynomial in x, right? So, carefully pick out the constant- and linear-order terms of this polynomial by choosing the appropriate factors in the determinant.
ok that's the idea behind...but what about some explicit calculations? Are them possible? I thought i can use the general determinant expansion in terms of the total antisymmetric tensor which, for a nxn matrix A must be something like
[tex] det A = \frac{1}{n!} \sum_{i_1, i_2, ... , i_n = 1}^{n} \epsilon_{i_1\;i_2\;...\;i_n} A_{1\;i_1} A_{2\;i_2} A_{3\;i_3} ... A_{n\;i_n}[/tex]
the expression of the fact that the determinant is the average of all possible products of the elements picked one per column keeping them in different rows, thanks to totally antisymmetric tensor.
Any idea to be a bit formal?
There should be no 1/n! in there. The determinant is the anti-symmetrized sum of all the products; not the average.
If you want to do the proof formally, the simplest way would be to diagonalize A. Or in general, bring A to upper-triangular form by a similarity transformation. Note that the identity matrix is invariant under similarity transformations. The determinant and trace are also invariant.
