Transcendental Functions Containing Natural Logs
6 replies · 2K views · last reply
WhiskeyHammer
Evaluate the integrals
a) y=
Definite integral from 2 to 4 of dx divided by x times (ln x) squared, written as a printed equation.
b) y=
Definite integral from 1 to 2 of 2 ln x / x dx, written as an integral sign with limits 1 and 2 over the integrand 2lnx/x and dx.
Worked example of the integral of f'(x)/f(x) dx equals ln|f(x)| + C, then Example 3 evaluating the integral from 0 to 2 of 2x/(x^2 - 5) dx using u = x^2 - 5, giving ln|-1| - ln|-5| = -ln 5.
I've tried using the Reciprocal Rule and substitution of each ln function with u to get a workable result, but haven't come anywhere near a recognizable solution. The answers stated in the book are as follows:
a) 1/ln4
b) (ln2)^2
[STRIKE]This tells me that, somehow a must end up looking like this:
ln 1 - ln 4
and b must look like:
ln2 * ln2[/STRIKE]
These would seem counter intuitive to my understanding of how these kinds of problems are solved and I am at a loss of how to fix it.
You want the anti-derivative (definite integral), not the derivative, and there is no ##y## in either problem. In both problems try the substitution ##u=\ln x##.
a) 1/ln4
ln 1 - ln 4
1/ln(4) ≠ ln(1) - ln(4), so it would be good for you to review the properties of logs.
The expression on the right can be simplified like so:
ln(1) - ln(4) = 0 - ln(4) = ln(1/4)
Note the ln(1/4) is a negative number, while 1/ln(4) is positive, so they couldn't possibly be equal.
I see the intent in setting up the integral as ##u*du## and anti-deriving to ##2u## but I don't see how ##du## could possibly equal ##1/x*dx## the derivative of ##\ln x## is ##(1/x)(d/dx*x)## which leaves us with ##u*du*dx## right?
I also updated the errors in my original post. Thanks for catching them, I am definitely on the tail end of burned out.
No. If u = lnx, then du = d(lnx) = d/dx(lnx)*dx = 1/x * dx
Ouch! The anti-derivative of u is [itex](1/2)u^2+ C[/itex]
Your original integral was
[tex]\int \frac{dx}{x ln(x)}[/tex]
(the second "dx" must be a typo.)
If you let u= ln(x) then [itex]du= \frac{1}{x}dx= \frac{dx}{x}[/itex] so the integral becomes
[tex]\int\frac{dx}{x ln(x)}= \int \frac{1}{ln(x)}\frac{dx}{x}= \int \frac{1}{u}du[/tex]
"the derivative of ##\ln x## is ##(1/x)(d/dx*x)## "
I can't make sense of that! The derivative of ln(x) is 1/x. Perhaps you mean (1/x) times the derivative of x with respect to x. That last would be 1 so that is the same as 1/x. Having written du/dx= 1/x, in differential terms, du= (1/x)dx.
Thanks guys, despite the errors on my part, you suggestions and clarifications were awesome and I got it worked out :biggrin:
