Transform a vector from Cartesian to Cylindrical coordinates
11 replies · 12K views · last reply
VinnyCee
Transform the vector below from Cartesian to Cylindrical coordinates:
[tex]Q\,=\,\frac{\sqrt{x^2\,+\,y^2}}{\sqrt{x^2\,+\,y^2\,+\,z^2}}\,\hat{x}\,-\,\frac{y\,z}{x^2\,+\,y^2\,+\,z^2}\,\hat{z}[/tex]
Use these equations:
[tex]A_{\rho}\,=\,\hat{\rho}\,\cdot\,\overrightarrow{A}\,=\,A_x\,cos\,\phi\,+\,A_y\,sin\,\phi[/tex]
[tex]A_{\phi}\,=\,\hat{\phi}\,\cdot\,\overrightarrow{A}\,=\,-A_x\,sin\,\phi\,+\,A_y\,cos\,\phi[/tex]
[tex]A_z\,=\,A_z[/tex]
[tex]x\,=\,\rho\,cos\,\phi[/tex]
[tex]y\,=\,\rho\,sin\,\phi[/tex]
[tex]Q_{\rho}\,=\,\frac{\sqrt{\left(\rho\,cos\,\phi\right)^2\,+\,\left(\rho\,\sin\,\phi\right)^2}}{\sqrt{\left(\rho\,cos\,\phi\right)^2\,+\,\left(\rho\,\sin\,\phi\right)^2\,+\,z^2}}\,cos\,\phi[/tex]
[tex]Q_{\rho}\,=\,\frac{\rho}{\sqrt{\rho^2\,+\,z^2}}\,cos\,\phi[/tex]
[tex]Q_{\phi}\,=\,-\,\frac{\rho}{\sqrt{\rho^2\,+\,z^2}}\,sin\,\phi[/tex]
[tex]Q_z\,=\,-\,\frac{z\,\rho\,sin\,\phi}{\rho^2\,+\,z^2}[/tex]
Does the above look correct?
Hi VinnyCee! :smile:
No … these are the equations for an ordinary rotation of the x and y axes through an angle phi.
hmm … you want polar coordinates of a vector along the x-axis … so what will its phi coordinate be? :smile:
Really? The equations for transforming from Cartesian to Cylindrical were given in the notes for the class in a matrix form and then solved out to a formula, the one below.
Here is a more detailed version for the [itex]\rho[/itex] coordinate transformation only:
[tex]A_{\rho}\,=\,\hat{\rho}\,\cdot\,\overrightarrow{A} \,=\,\left(\hat{\rho}\,\cdot\,\hat{x}\right)\,A_x\,+\,\left(\hat{\rho}\,\cdot\,\hat{y}\right)\,A_y\,+\,\left(\hat{\rho}\,\cdot\,\hat{z}\right)\,A_z\,=\,A_x\,cos\,\phi\,+\,A_y\,sin\,\phi[/tex]
Is that incorrect? If so, what is the correct way to transform from Cartesian to Cylindrical?I think the [itex]\phi[/itex] coordinate would be zero in this case since there is no y-component, right?
Here you've included the Ax cos(phi) term, but forgot the Ay sin(phi) term
[itex]A_y[/itex] is zero, so it need not be included, right?
Oops, I was confusing Ay and Az. My bad.
Your results from post #1 look okay to me. My understanding is the dot product of the vector Q with the coordinate unit-vector is the component of Q in that coordinate direction, which is exactly what you did.
On the other hand I'm hesitant to disagree with tiny-tim, since he knows this stuff pretty well also.
That's right! for x > 0 and y = 0, phi must be zero. :smile:
No!
A three-dimensional vector needs three coordinates …
if one coordinate is 0, you have to say so!
Is that incorrect?
No, that is correct … the other one is wrong.
Redbelly98 said:
Isn't that the same expression as in post #1 for Aρ ?
ah … I meant the phi-coordinate [tex]A_{\phi}\,=\,\hat{\phi}\,\cdot\,\overrightarrow{A}\,=\,-A_x\,sin\,\phi\,+\,A_y\,cos\,\phi[/tex] is wrong. :wink:
Um, if we use the convention that φ's unit vector points counterclockwise, and φ is taken counterclockwise from the positive x-axis, then I agree with VinnyCee's formula.
So, does that mean that the original post contains the correct answer? Or is the [itex]Q_{\phi}[/itex] variable still going to be zero even though the formulas given produce the expression I wrote in the first post?
The expression written from a matrix in class is:
[tex]A_{\phi}\,=\,\hat{\phi}\,\cdot\,\overrightarrow{A} \,=\,\left(\hat{\phi}\,\cdot\,\hat{x}\right)\,A_x\,+\,\left(\hat{\phi}\,\cdot\,\hat{y}\right)\,A_y\,+\,\left(\hat{\phi}\,\cdot\,\hat{z}\right)\,A_z\,=\,-A_x\,sin\,\phi\,+\,A_y\,cos\,\phi[/tex]
Since...
[tex]\hat{x}\,\cdot\,\hat{\phi}\,=\,-\,sin\,\phi[/tex]
[tex]\hat{y}\,\cdot\,\hat{\phi}\,=\,cos\,\phi[/tex]
[tex]\hat{z}\,\cdot\,\hat{\phi}\,=\,0[/tex]
Right?
sorry!
Hi VinnyCee and Redbelly98! :smile:
Yes, I completely mis-read the original question.
Your original answer was totally right.
Please ignore my previous posts.
Sorry. :redface:
