What Is the Correct Current Equation to Induce Given Flux in a Circuit?
  • Thread starter Thread starter Sarah0001
The discussion centers on determining the correct equation for current that induces a given magnetic flux, represented by Φ = sin ωt. The initial assumption is that the induced current, I, should be directly proportional to the flux, leading to the equation I = Ksinωt. However, confusion arises regarding the negative sign in the provided answer, I = -Ksinωt, which relates to the principle that induced current opposes the change in flux according to Lenz's Law. Participants are encouraged to explore the relationship between current and flux in a wire loop to clarify this concept. The conversation highlights the importance of understanding the dynamics of induced current and flux in electromagnetic circuits.
Sarah0001
1. Problem Statement:
flux in a flux circuit varies according to the equation Φ = sin ωt.
Using a constant k, what is the equation for a current which could induce the flux in the flux circuit above?
Φ = sin ωt.
The answer given is :
e12ee062d538a768a369f9e7806a3248f1c870b0
My attempt at this solution is, that Current that induces the flux (regardless of whether the flux varies or not due to current) and is directly proportional to the flux as a result . Flux and current are in phase is my understanding (correct me if I'm wrong).
Thus. I = Ksinwt
however the answer gives -Ksinwt, I am confused on how they get the -ve
I know Emf induced and thus the current induced are proportional to the (-ve) rate of change of flux linkage,
however the question asks for a current which would induce the flux, not the other way round (where only a change of flux could only induce current) ,
hence it would be solely a proportional relationship between current and flux (flux dependent on current),
so surely the answer is Ksinwt as nothing is being opposed - I am unsure what the negative is indicating here about the current if the answer given is correct.
Look for an equation that relates the flux through a wire loop versus the current flowing through the loop. If you drive a sinusoidal current through a wire loop, what is the equation for the flux as a function of time through the loop's area? :smile:
Likes Sarah0001
Hi, thank you for your response. I am unsure what what equation that would be and how it helps to solve the question.
