Transpose Problem: Solving Steering Geometry
  • Context: Graduate
  • Thread starter Thread starter ZachGriffin
    Transpose
The discussion revolves around a problem in steering geometry involving the transposition of an equation to solve for an angle (Vf) related to the position of a point (P1) in three-dimensional space. Participants explore the mathematical relationships between various components, including vectors and trigonometric identities, while attempting to isolate Vf.
  • One participant describes the equation for P1 in terms of known quantities and expresses difficulty in isolating Vf due to its presence in multiple terms.
  • Another participant suggests using the angle addition identities to simplify the equation into a form involving sine and cosine.
  • A later reply discusses the complexity of dealing with 3D vectors and the challenge of having multiple instances of the variable Vf in the equation.
  • One participant proposes a path to express Vf in terms of other variables, but notes the need for additional equations to resolve multiple unknowns.
Participants do not reach a consensus on how to effectively isolate Vf, with multiple competing approaches and unresolved issues regarding the presence of multiple unknowns in the equations.
The discussion highlights limitations in the current approach, including the dependence on vector definitions and the unresolved nature of the mathematical steps required to isolate Vf.
ZachGriffin
Hey guys,
So I've actually learned a fair bit about trig identities the last few weeks and beginning to understand how they actually work thanks to Irrational, Mute and some prompting from Hurkyl.
I'm still having trouble with transposing which I think should be fairly simple. The equation is solving steering geometry with two points of rotation that locates two points in space. The equation which works out the length between two points is:
D = | P1 - P2 | with | | denoting the length of the resulting 3D vector.
I know D (the length) and I also know P2 (the x,y,z position of point 2). P1 is what I'm having trouble with. The equation for P1 is:
P1 = Pf + (i1f * Rf * cos(Vf)) + (i2f * Rf * sin(Vf))
I know Pf (the x,y,z position of the axis of rotation), i1f (the x projection vector of P1's rotation axis), Rf(the length between P1 and the axis of rotation) and i2f(the y projection vector of P1's rotation axis).
From those I know all but Vf, which is an angle from P1 to the x-axis and P1, which is solvable by substituting it into the 1st equation D = | P1 - P2 |.
Vf is where I'm having the problem. How can I transpose it to make it the subject. I've tried using the identity R * cos(x - alpha) but still have the same problem of having 2 instances of Vf in the equation as in P1.x, P1.y and P1.z will all use different values for R and alpha. I hope this makes sense. If not I'll post up the images from the white paper I'm using. Any help is much appreciated.
Mathematics news on Phys.org
I've attached the excerpt anyway:
Can anyone help here or point me in the right direction? I'm really stuck with this and it doesn't matter which theorem I apply, I still end up with 3 instances of x on the same side of the equation.
ZachGriffin said:
Hey guys,
After simplification, you should be left with an equation of the form k = Acos(t) + Bsin(t). Using the angle addition identities, you should be able to get k = Csin(t + p) where [itex]C = \sqrt{A^2 + B^2}[/itex] and p = arctan(A/B).
Thanks for responding slider. When I expand it out, I have something like this:
k = [tex]\sqrt{}[/tex] (A.xCos(t) + B.xSin(t))[tex]^{2}[/tex] + (A.yCos(t) + B.ySin(t))[tex]^{2}[/tex] + (A.zCos(t) + B.zSin(t))[tex]^{2}[/tex]
Is there a way to simplify it because A and B are 3D vectors? I can use the Rcos(x-alpha) like you suggested but I still end up with 3 instances of t on the right side for each component of A and B.
ZachGriffin said:
Hey guys,
My path was to first get the equation:
[tex]\frac{P_1 - P_f}{R_f} = i_{1f}\cos V_f + i_{2f}\sin V_f[/tex]
Then we have
[tex] C = \sqrt{i_{1f}^2 + i_{2f}^2}[/tex]
[tex]\theta = \arctan \frac{i_{1f}}{i_{2f}}[/tex]
Expanding and simplifying, we get
[tex] \frac{P_1 - P_f}{R_f} = \sqrt{i_{1f}^2 + i_{2f}^2}\sin (\arctan \frac{i_{1f}}{i_{2f}} + V_f)[/tex]
or
[tex] V_f = \arcsin\left(\frac{P_1 - P_f}{R_f\sqrt{i_{1f}^2 + i_{2f}^2}}\right) - \arctan\frac{i_{1f}}{i_{2f}}[/tex]
Edit: Oh, I see, the i's are vectors. you will have to use one of the 3 component equations.
Ok thanks. So assuming I use the x component for the equation I still have two unknowns being Vf and P1.x. Do I need another equation to work out what P1 is?
18K
