Treating a projectile like a rotational system?
The discussion revolves around a projectile motion problem where a mass is launched at an angle from the ground, and participants are exploring how to analyze it using concepts from rotational dynamics, such as torque, angular velocity, moment of inertia, and angular momentum.
  • Mixed
  • Participants are questioning how to relate projectile motion to rotational systems, particularly regarding the forces acting on the projectile and the implications for torque. There are discussions about the nature of the gravitational force and its effect on torque at different points in the projectile's trajectory.
The discussion is ongoing, with participants providing insights into the definitions of torque and angular momentum. Some are clarifying the conditions under which torque is calculated and the significance of the torque vector in this context. There is no explicit consensus yet, but several productive lines of inquiry are being explored.
Participants are working under the assumption that the projectile is treated as a point mass and are considering the implications of using different reference points for torque calculations. The problem's setup and the teacher's emphasis on specific quantities are also points of discussion.
LiliPling
A projectile of mass m is fired from ground level with speed v0 and at angle ##\theta## with respect to the horizontal. Basically there is a projectile from start to finish, with an pivot starting at the x coordinate for the highest point on the projectile. The teacher wants us to find the net torque vector, angular velocity vector, moment of inertia, and angular momentum vectors.
I have trouble understanding how projectile motions can even be looked at like a rotational system. To me, the only force ever acting is gravity, but then the projectile is rotating around the origin, so shouldn't that mean that there's also another torque force?
If the only force is g, then the torque would be mgr (r is the distance from the pivot) at the start point and then 0 at the top (since the g force is towards the pivot so no force done)? Also why does the teacher emphasize looking for the torque VECTOR? Does that mean that it's point towards us?
Welcome to PF!
Is this problem in reference to orbiting the Earth ?
Nope! It's literally just a projectile (an object being thrown) and then treated like a rotational system.
You consider the Earth ground as an infinite plane with gravity vector vertical to it or you treat the Earth ground as spherical and the gravity vector in the radial direction?
Is this just the standard projectile problem but to be solved using polar coordinates instead of the more commonly used Cartesian coordinates ?
The former.
The problem does state that its being launched horizontally (zero degrees to the horizontal) right?
No! It's being launched at an angle (like 45 degrees or something)!
A projectile of mass m is fired from ground level with speed v0 and at angle -0- with respect to the horizontal. Basically there is a projectile from start to finish, with an pivot starting at the x coordinate for the highest point on the projectile. The teacher wants us to find the net torque vector, angular velocity vector, moment of inertia, and angular momentum vectors. ?
Sorry haha what i was trying to do was make the theta sign, but I guess it looks like a 0, sorry. The angle is assumed to be non zero though.
Okay so the projectile is launched at some angle from x=0 and y=0 into the air and gravity pulls on it so that it will follow a parabolic path.
That curved path implies that it has angular momentum so do you know how to compute its angular momentum vectorially?
So you agree that the only force for the torque is the graviity?
So the torque can be computed by Fr?? and is mgr at the (0,0) and is 0 at the peak?
jedishrfu said:
Isn't torque defined as T = r x F ?
Isn;t that what i wrote?
Torque is a vector quantity and you use the r x F to compute it, the magnitude of T is ## |T| = |r| |F| sin \theta## where ##\theta## is the angle between r and F and the direction of the torque follows the righthand rule from r to F and the righthand thumb points in the direction of T.
What would be the torque vector in this case given the information.
I think mgr, and can;t think of any other possibility. Please give your insight? :)
Yes, I reread your problem and I think you're right as the pivot point is the x value of where the particle is highest and y=0 so you'd use it to compute the torque but since the force is parallel to the r vector then the torque magnitude is zero at that point.
Perhaps @Doc Al can add more to the discussion here as my physics is somewhat rusty.
LiliPling said:
A projectile of mass m is fired from ground level with speed v0 and at angle θθ\theta with respect to the horizontal. Basically there is a projectile from start to finish, with an pivot starting at the x coordinate for the highest point on the projectile.
OK. I'll interpret that, like jedishrfu did, as wanting you to use that point on the ground directly under the projectile when it's at max height as your reference point for your calculations.
Good. You should know the definitions of those quantities.
The only force is gravity. Note that we are not talking about the projectile rotating about its center, but just ordinary projectile motion. (Think of it as a point mass-- a ball, perhaps.) And further realize that a point mass can have angular momentum and rotational inertia about some point as well as be subject to a torque about that point.
Yes, the torque is zero at the top. The force (gravity) doesn't change as the projectile moves, but the torque does.
To make sure you understand the concept!
At what point in the projectile's motion? (Compare the direction of the torque vector before and after the projectile reaches the highest point.)
  • · Replies 35 ·
  • · Replies 25 ·
  • · Replies 30 ·
