MHB Prove Triangle Inequality: $\sqrt{2}\sin A-2\sin B+\sin C=0$
In triangle ABC, the condition $\sqrt{2}\sin A - 2\sin B + \sin C = 0$ leads to the inequality $\frac{3}{\sin A} + \frac{\sqrt{2}}{\sin C} \ge 2(\sqrt{3}+1)$. It is established that if the angle condition is satisfied, the inequality will always hold true. A specific case where equality is achieved occurs when $A = \frac{\pi}{3}$ and $C = \frac{\pi}{4}$. The discussion suggests that there may be multiple triangles fulfilling these criteria. Overall, the relationship between the angles and the derived inequality is consistently valid within the defined parameters.
anemone
MHB
POTW Director
In a triangle $ABC$ with $\sqrt{2}\sin A-2\sin B+\sin C=0$, prove that $\dfrac{3}{\sin A}+\dfrac{\sqrt{2}}{\sin C}\ge 2(\sqrt{3}+1)$.
Mathematics news on Phys.org
I can find _a_ triangle that satisfies $\sqrt{2}\sin A-2\sin B+\sin C=0$ where $\dfrac{3}{sin A}+\dfrac{\sqrt{2}}{\sin C}\ge 2(\sqrt{3}+1)$ but you use $\ge$ , does this mean there are a multitude of triangles that meet these requirements?
To find my triangle I use the equalities: $\dfrac{sin A}{a} = \dfrac{sin B}{b} = \dfrac{sin C}{c}$
I rearrange your equation to: $\sqrt{2}\sin A+\sin C=2\sin B$ and let $b = 1$ then
$\sqrt{2}\sin A+\sin C=2\dfrac {sin B}{b}$. Now since $\dfrac {sin B}{b} = \dfrac{sin C}{c} = \dfrac{sin A}{a}$
we can write
$\sqrt{2}\sin A+\sin C= \dfrac{sin A}{a} + \dfrac{sin C}{c}$
and if we let $a = \dfrac {1}{\sqrt{2}}$ and $ c = 1$ then our equation is satisfied.
Now that we have found the 3 sides of our triangle we can find the 3 angles. From my CRC handbook I find
$\cos A = \dfrac{b^2 + c^2 - a^2}{2bc} = 0.75$
$\cos B = \dfrac{c^2 + a^2 - b^2}{2ca} = 0.3536$
$\cos C = \dfrac{a^2 + b^2 - c^2}{2ab} = 0.3536$
Converting to the angles in degrees I get:
$A = 41.41 , B = 69.30 , C = 69.30 $ (as a crosscheck we can see that they sum to 180)
and then
$\dfrac{3}{sin A} + \dfrac{\sqrt{2}}{sin C} = \dfrac{3}{sin 41.41} + \dfrac{\sqrt{2}}{sin69.30} = \dfrac{3}{0.6614} + \dfrac{\sqrt{2}}{0.9354} = 4.5358 + 1.5119 = 6.0477$ and this is greater than $2(\sqrt{3}+1) = 5.4641$.
The question says as long as we can prove that the angles in a triangle $ABC$ satisfy $\sqrt{2}\sin A-2\sin B+\sin C=0$, then $\dfrac{3}{\sin A}+\dfrac{\sqrt{2}}{\sin C}\ge 2(\sqrt{3}+1)$ will always hold. (Nod)
The other comment that I have for this unsolved challenge is that the equality holds when $A=\dfrac{\pi}{3}$ and $C=\dfrac{\pi}{4}$.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
