Graduate Why Is the Discriminant Non-Positive in the Triangle Inequality Proof?
The discussion centers on the derivation of the triangle inequality, specifically the quadratic inequality formed by substituting z = x - ty. The discriminant of this quadratic, D = 4(Re(x,y))^2 - 4||y||^2||x||^2, is shown to be non-positive, indicating that the solutions are either complex conjugates or a single real solution. This non-positivity ensures that the quadratic function remains non-negative for all real t, meaning it can only touch the t-axis at one point or not at all. The conclusion emphasizes that the function must always be zero or positive, reinforcing the validity of the triangle inequality.
LagrangeEuler
In the derivation of triangle inequality |(x,y)| \leq ||x|| ||y|| one use some ##z=x-ty## where ##t## is real number. And then from ##(z,z) \geq 0## one gets quadratic inequality
||x||^2+||y||^2t^2-2tRe(x,y) \geq 0
And from here they said that discriminant of quadratic equation
D=4(Re(x,y))^2-4 ||y||^2|x||^2 \leq 0
Could you explain me why ##<## sign in discriminant relation? When discriminant is less then zero solutions are complex conjugate numbers. But I still do not understand the discussed inequality. What about for example in case
||x||^2+||y||^2t^2-2tRe(x,y) \leq 0?
The quadratic equation
must always be zero or positive for all real ##t##. This means the function ##f(t)=||x||^2+||y||^2t^2-2tRe(x,y)## must always be above the ##t## axis, which further implies that it can have at most one solution (which occurs when the minimum of this function touches the ##t## axis): one solution or no solution at all. In terms of the discrimant, the discrimant of ##f(t)## is either zero or negative.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 25 ·
  • · Replies 26 ·
  • · Replies 17 ·
