Proving Convergence of Complex Series with Cauchy Condition | Homework Help
  • Thread starter Thread starter gustav1139
    Complex Series
The discussion centers on proving the convergence of complex series under the Cauchy condition, specifically that if the series \(\sum{a_{n}b_{n}}\) converges for every complex sequence \(\{b_{n}\}\) with \(\lim{b_{n}}=0\), then \(\sum{|a_{n}|}<\infty\). Participants explored various approaches, including the contrapositive method and the ratio test, ultimately leading to a successful proof using a specific choice of \(b_k = \frac{\overline{a_i}}{c_i |a_i|}\). This choice ensures that the terms converge to zero while maintaining the necessary conditions for convergence.
  • Understanding of complex sequences and series
  • Familiarity with the Cauchy convergence criterion
  • Knowledge of the ratio test for series convergence
  • Basic principles of real analysis, including the mean value theorem for integration
  • Study the Cauchy convergence criterion in depth
  • Learn about the properties of complex sequences and their convergence
  • Explore proof techniques in real analysis, particularly proof by contradiction
  • Investigate the application of the mean value theorem in complex analysis
Mathematics students, particularly those studying complex analysis and series convergence, as well as educators seeking to understand advanced proof techniques in real analysis.
gustav1139
Suppose that \left\{a_{n}\right\} is a sequence of complex numbers with the property that \sum{a_{n}b_{n}} converges for
every complex sequence \left\{b_{n}\right\} such that \lim{b_{n}}=0. Prove that \sum{|a_{n}|}&lt;\infty.
I tried going directly, at it, using the Cauchy condition on \sum{a_{n}b_{n}} to try to figure something out about the a_{n}, but I got bogged down, and all the inequalities seemed to be pointing the wrong direction.
Then I tried to prove the contrapositive, that if \sum{|a_{n}|} diverges, then there exists a sequence \left\{b_{n}\right\} such that \sum{a_{n}b_{n}} diverges as well. But I didn't get very far with that either.
I was able to prove it using the ratio test (i.e. if \lim{\frac{a_{n+1}b_{n+1}}{a_{n}b_{n}}}=r where r\in(0,1)), but that's unfortunately not a necessary condition for convergence.
So I'm stuck, and frustrated :(
What you need to prove is that if \displaystyle \int_{0}^{\infty} a(x)b(x)\,dx has a finite value, so must \displaystyle \int_{0}^{\infty} |a(x)|\,dx. You can get around the absolute value assuming that a(x) resolves to a non negative real number for every x.
Try using the first mean value theorem for integration.
Thanks! I'll give that a try, but isn't it an issue that they're complex sequences, if I want to use the MVT?
Also, why can you assume a(x) is a nonnegative real? Or perhaps I'm misunderstanding what you mean by resolve.
gustav1139 said:
Then I tried to prove the contrapositive, that if \sum{|a_{n}|} diverges, then \sum{a_{n}b_{n}} must diverge as well. But I didn't get very far with that either.
You didn't get the contrapositive quite right. Consider, for example, an=1 and bn=1/n2. \sum{|a_{n}|} diverges but \sum{a_{n}b_{n}} doesn't.
You should have said: if \sum{|a_{n}|} diverges, then there exists a sequence {bn} such that ##\displaystyle\lim_{n \to \infty} b_n = 0## and \sum{a_{n}b_{n}} diverges.
That said, I don't have any comment about how to actually do the proof. Just wanted to point out your error.
You could make a proof by contradiction. Suppose ## \sum | a_i|## diverges. Therefore you can find a sequence of integers ##k_n## such that the partial sums ## \sum_{k_{n-1}+1}^{k_n} | a_i| > 1## for n = 1, 2, 3 ...
Now choose a series of b's that converge to 0, such that ##\sum a_ib_i## diverges.
Hint: you can choose b's such that every term ##a_i b_i## is real and non-negative...
Right you are. All fixed.
That (what you said) is however what I'd been working with so that's still no go...
Thanks! I think that broke it open. I had been restricting myself unnecessarily with what I could assume if ##\sum|a_i|## diverged.
I picked ##b_k = \frac{\overline{a_i}}{c_i |a_i|}## where the c's are the largest n such that i > k_n. Then the b's go to 0 since they do in modulus, and you can group the terms in the product series to give something bounded below by the harmonic series. boom.
